Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: SLAMing
    May 2015
    Coventry, RI
    11
    SLAMing
    Hi. Total newb here. I'm trying to wrap my head around some things. I bought a house with a neglected pool. Trying to clean it up without draining. Made a little progress as pool was black and is now greenish. I replaced the sand in the filter as well. My question is in regards to slam. My test showed CC as .07 and FC as .06. So in my mind, to slam, I would have a target chlorine of .7 (10x CC). That just sounds wrong so with the numbers I'm set at a target of 10. But, in my brain, as FC is used it becomes CC. So would I not have to continually raise my target level?
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: SLAMing
    First we need tests. Are you using one of the recommended Taylor kits?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: SLAMing
    Welcome to the forum. POINT 07 and POINT 06 don't mean anything unless you are saying both those values are less than <1>. Your SLAM value will be determined by your CYA level.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SLAMing
    Welcome to the forum Danny,
    Yes, those levels of FC will not do much of anything...even 10.0 FC. You need to have some Cya in the water, and anywhere close to the correct amount will negate 10 FC. Tell us about your kit/testing and we can go from there. Next stop should be Pool School and a start with that in the ABC's. You can find that, and how to SLAM your pool in my signature links. Let us know, and how we can help. Good luck on your SLAM!
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: SLAMing
    Welcome to TFP! As mentioned we need test results to give good advice.
    FC level is determined by CYA level on the Chlorine CYA Chart
    Please update your signature info as described here
    Here are a couple of articles in Pool School to get you started.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals needed to maintain your pool.
    And use PoolMath to determine how much to add.
    Since your pool is swampy you are going to have to SLAM your pool following this process for SLAMing Your Pool.
    But, first thing you need to do is order a fantastic test kit. I prefer the TF100 from tftestkits.net, get the XL version.
    May 2015
    Coventry, RI
    11
    Re: SLAMing
    Yes, both read less than 1. Total chlorine is .13. Test results below.
    TC - .13
    FC - .06
    CC - .07
    Alk - 33
    PH - 7.4
    CH - 105
    CYA - 3
    Pool is 15x4 round AG. Around 5000 gallons.
    Pool is green. Like I said, it was black.
    But I was curious to how the shock is going to work if my FC is constantly converted to CC and then I need more FC to combat the higher CC (10x CC). I know my alk and CYA are low. But pool store said worry about those after clearing the pool. Maybe wrong? Pool seems cloudy and green. A lot better than originally, but not anything I want to climb into.
    38,301
    Re: SLAMing
    What test kit are you using? Those numbers make no sense.
    Forget the 10x CC non-sense. It is not true.
    Just keep adding FC to target your shock level and eventually the CC will drop and the FC will start to hold. Then follow the ShockLevelAndMAINTAIN Process. But you need one of the Recommended Test Kits to do it correctly.
    May 2015
    Coventry, RI
    11
    Re: SLAMing
    Test was an electronic test at pool store. Not a national chain like leslies, a mom and pop shop.
    What should my target be? I thought the target for shock level was 10x CC?
    Jul 2014
    Pittsburg, KS
    31
    Re: SLAMing
    I'm a little surprised that no one has jumped on here and told you to forget the pool store test yet!
    Here's what the pro's on this site are going to tell you:
    1. Drop the pool store and get one of the recommended test kits. http://www.troublefreepool.com/conte...its-comparison
    2. No need to reinvent the wheel in this post. Read all of the articles that pooldv listed in Post #5 above.
    3. Click on Pool School at the top and READ EVERYTHING!
    Your target FC during SLAM depends on your CYA level. It has nothing to do with CC.
    Intex UltraFrame 14ft x 48in deep, 3,700 Gallon, Intex 14-Inch Krystal Clear 1,600 gph Sand Filter Pump, Taylor K-2006
    38,301
    Re: SLAMing
    I certainly do not trust electronic pool testers. You need a kit to do the SLAM.
    We do not "shock" like pool stores tell you to do. We have a process that you need to follow. The FC level you need to maintain is listed in the FC/CYA Chart.
    May 2015
    Coventry, RI
    11
    Re: SLAMing
    ok, im not understanding the slam process. should I stop doing chlorine until the rest of chems are in order (alk, ch, cya, etc)?
    38,301
    Re: SLAMing
    At this point we have no idea what any of your levels are because those results are suspect. So no way to know what you should adjust first.
    What do you not understand about the ShockLevelAndMAINTAIN Process?
    Might help if your question was a little more specific.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: SLAMing
    We need some Taylor testing action
    DFW, TX
    24,497
    Re: SLAMing
    Quote Originally Posted by Dannyp02908 View Post
    I think it is time to go back up to post #5 and do a little reading.
    May 2015
    Coventry, RI
    11
    Re: SLAMing
    At this point, I am just going to throw in the towel. I don't have the time to devote nor the patience to deal with it. Grass is easier and the beach is free. Thank you for the suggestions but I guess this pool thing isn't for me.
    Jul 2014
    Peoria, IL
    389
    Re: SLAMing
    I have felt your pain. Kept getting cloudy water outbreak after cloudy water out break. My next step was a dozer and a big pile of dirt. The great folks here saved her from the wrecking ball.
    I know I am beating a dead horse here but the first thing that you need to do is invest a few dollars in a test kit. Either the kit you can get here or a Taylor 2006 that you can get anywhere. I got mine via Amazon.
    Trust me when I tell you that the test kit will save you tons of money over getting "pool stored" with chemicals for as long as you have the pool.
    Hope you are able to take a step back and gather your thoughts and go back at it.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    May 2015
    Coventry, RI
    11
    Re: SLAMing
    I tried to step back. I live 20 minutes from misquamicut beach. This is to much to figure out over what's basically a kiddie pool.
    38,301
    Re: SLAMing
    Bet the pool would be warmer
    If it is a kiddie pool, drain it and start over following this: http://www.troublefreepool.com/conte...emporary-pools
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: SLAMing
    That works. You have to decide what is worth the time to devote to it.
    Sorry it didn't work out.
    Support the site
  20. Back To Top    #20
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,093
    Re: SLAMing
    With this type of pool without a doubt your best and quickest bet is to simply dump the water. It will likely cost you around $20 to refill and you'll be up and running in a weekend. Follow the Guide for Seasonal Pools and enjoy what you got. If it turns green........time to dump again.
