Thread: DE filter questions for Bama Rambler
    Quote Originally Posted by Bama Rambler View Post
    Here you go. Measured from bottom to middle of air relief valve.
    DE2420 = 32" -- 3lb DE
    DE3620 = 34.1" -- 4.5lb DE Edited to correct model number. Thanks Paul
    DE4820 = 40.1" -- 6lb DE
    DE6020 = 46.1" -- 7.5lb DE
    DE7220 = 52" -- 9lb DE
    When you say measure form the bottom are you referring to the ground or bottom of the filter where it starts to curve under? Hope that makes sense. Been looking to determine what size my DE filler is and stumbled across this post. Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: DE filter questions for Bama Rambler
    Welcome to the forum!
    Essential Links:
    22,553
    Measure from the bottom of the base. I hesitate to say ground because there will be someone who has a filter sitting on a raised pad and they'll try to measure from ground level . But yes from where it sits on the ground if it's sitting on the ground!
