Results 1 to 7 of 7
Thread: Anyone build a filter for a separate cleaning pump?
    Jun 2012
    Oakton,Va
    39
    I acquired a separate pump that I am setting up as a stand alone vacuum pump. Currently I using a skimmer sock as a filter but I wanted to build some kind of filter to dump the water through and clean the algae areas while I open the pool. Has anyone built something like this?
    35000 gallon inground, 2hp Whisperflo, Pentair FNS Plus, Polaris 380
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Anyone build a filter for a separate cleaning pump?
    I commented on one I saw in Jamaica.
    Thread Here
    Support the site
    At our golf course we built a vacuum pump system then plumbed it with a small cartridge filter and put it on a dolly like thing.
    Jun 2012
    Oakton,Va
    39
    That would work. Now I just need to find a cheap cartridge filter.
    May 2014
    Franklin, NC
    9,193
    You could pick up an inexpensive hand truck at Harbor Freight to mount everything to and it would be portable. Problem is that the only Harbor Freight is on the MD side of the American Legion Bridge.
    Support the site
    This is like the filter we have. Pentair R172502 25 Square Feet Cartridge Replacement, Pool and Spa Dynamic Series II RTL 25 Top Load High Flow Cartridge Filter https://www.amazon.com/dp/B006H412FA..._9ibtvb0N01N4F
    Jun 2012
    Oakton,Va
    39
    The filter is a perfect size. Thanks! Harbor Freight - No way they opened one in Sterling a year or so ago.
