Results 1 to 9 of 9
Thread: Return jets
    Return jets
    I've been looking around and can't find anyone who has this issue. I just bought a house in January where the former owner would appear to have had had a disorder of the mental kind with all the unbelievable nonsensical issues that we have found in the house. That's another story though. The house has an inground pool, that I think is roughly 16x34. But I noticed that both return jets are placed in the shallow end. None are located in the deep end across from the skimmer! I grew up with pools and this is the first time I have ever seen this. The surface is constantly littered with **** because nothing is going into the skimmer. By the time the water gets to the dep end it really is barely moving let alone being directed into the skimmer. Has any one experienced this? And did you have a remedy for getting the surface moving into the skimmer? I can't believe a pool company would do this design. It is completely retarded and inefficient. Any suggestions how to get the water moving correctly so the skimmer can work?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Return jets
    Usually the best strategy is to try to promote a circular rotation in the pool. This is typically done by pointing the return eyeballs in the same direction, either clockwise or counterclockwise whichever seems to work best.
    Welcome to TFP!
    Re: Return jets
    Yes, I do have them pointed to get a circular motion, however the one eyeballs greatest angle, at best, 45°s across the pool. As well, with that distance the water retards the jets power so that about halfway there's very little noticeable movement. Ian contemplating doing a dye test to see if anything is getting to the skimmer at all. The surface is literally never clean.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Return jets
    Ping pong balls work great
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    Re: Return jets
    You don't say what size the openings are in your eyeballs, I have seen them with 1/2" on line. They would flow less by volume but at more pressure allowing you to focus more toward the surface which is what you are trying to move. Just my two cents...
    Ernie
    18' x 38' 20,500 gallon vinyl IGP, 3.5 - 7' depth, Pentair FNS Plus DE filter,
    2hp Whisperflo high performance pump, 1.1hp boost-rite pump for the cleaner,
    250k BTU MasterTemp heater, LetroLegend pool cleaner, Hayward TurboCell GLX-CELL-15 chlorine generator
    Speedstir, K-1776, TF-100
    DFW, TX
    24,468
    Re: Return jets
    That is true, smaller eyeballs, more pressure. I think mine are half inch. Sunplay.com has all sizes. Another idea is point them the other direction to see if that is better than what you have now.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Return jets
    You could get these and see if they make a differance, at 12 dollars its worth the try... I am going to be using 2 of these..
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Re: Return jets
    Thanks for the suggestions. I'm for sure going to look into better jets. I assume these are somewhere between 3/4" to 1"? An update as well, the pool company that opened the darn thing never opened the skimmer lines either. So it was drawing from the floor intake only. That has helped opening the skimmer line, but I need those jets to control the movement.
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Re: Return jets
    Quote Originally Posted by marc76 View Post
    Try to run circulation with skimmers being open and see what surface movement you can get.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
