Results 1 to 8 of 8
Thread: How soon can I use my SWG after adding CYA?
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    154
    I am on my second "sock in the skimmer" of CYA, so I've added about 3 lbs total. I started with 0 CYA so I have a while to go to get my CYA to the recommended level of 70-80.
    I currently have no chlorine in the water. Can I add liquid bleach now with the CYA sock in the skimmer basket? If not how long do I wait? Or, when will I be able to turn on my SWG? Pump and filter are running and water is clear.
    Thank you in advance for your assistance.
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: How soon can I use my SWG after adding CYA?
    Yes, go ahead no add chlorine manually to get some in there and start the SWG.
    Support the site
    Jul 2014
    Hickory, NC
    154
    Thank you!
    ~ TF-100 test kit
    May 2014
    Franklin, NC
    9,197
    Chlorinate based on the assumed level of CYA you have floating.
    Support the site
    Jul 2014
    Hickory, NC
    154
    PoolMath says to add 224 ounces of CYA (measured by weight) to get to a level of 70. So, when I add chlorine tomorrow evening I will assume all 48 ounces has been dissolved, which would be 21.4% of my total CYA added. 21.4% of 70 would be 14.98% of assumed CYA floating...is this a correct way to calculate?
    ~ TF-100 test kit
    May 2014
    Franklin, NC
    9,197
    How much have you actually added already buy weight.
    Support the site
    Jul 2014
    Hickory, NC
    154
    I would guesstimate about 1.5 lbs is currently in the water, and the other 1.5 lbs in the sock now.
    ~ TF-100 test kit
    May 2014
    Franklin, NC
    9,197
    If only 1.5 pounds is in the water chlorinate based on that. When you put the other 1.5 pounds in adjust accordingly. Chlorinate based on what is in the water, not where you plan to get to.
    Support the site
