Results 1 to 7 of 7
Thread: SWCG Increase Calcium in Water?
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    5,606
    New pool (shown in the Under Construction section). Looking for a pool service as we will be gone quite a bit over the summer. The service person and I were discussing what was needed with a SWG pool and he made a long statement how several states (California, Florida, etc) had tested SWG and shown that they increase the calcium in the water. I cannot figure the chemistry in that. Now our area has high CH source water (250) so it will increase over time in the pool with evaporation thus leading to a drain and fill every year or so. But the SWG adding calcium? Any thoughts?
    He also stated that we had to monitor phosphates in this area due to bird fecal matter causing yellow algae. Said they use Sodium Bromide as the chlorine does not kill it. Another one I cannot resolve --
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: SWCG Increase Calcium in Water?
    I think you found one guy to NOT hire
    Support the site
    May 2014
    Laughlin, NV
    5,606
    Tough part is another one I talked to was worse. Said no need to do any water testing. Just add what they always add!! Yikes!!
    Marty
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Oh my! As far as I know salt water does not magically convert to calcium. It will raise the total dissolved solids reading but that is not generally something you need to worry about.
    For the second question, as long as you maintain adequate chlorine levels the phosphate level does not matter. I can only imagine how many birds have to be pooping in your pool to create that yellow algae! As far as I can tell, this guy's advice is for the birds!
    Love TFP? Become a
    TFP Supporter!
    I would ignore the advice from that "service" person. SWGs don't add or raise calcium. Ask for copies of any state's studies that make such a claim. He won't be able to produce them.
    Sodium bromide should not be added. Phosphates can be ignored.
    Support the site
    Aug 2014
    Hopedale, MA
    18
    Don't fall for the phosphate story. I learned the hard way by listening to a pool store guy before I found TFP. Yes phosphates are food for algae, but if you're keeping your chlorine level where it needs to be, and killing the algae, then there is nothing to feed on the phosphates. Don't waste your money on phosphate remover, spend it on a good adult beverage by your sparkling clear pool.
    IG built in 2005, Vinyl, 18 x 39, 26,000 gallons, SWG Aqua T-Cell 15, timer is on for 12 hours (8 hours of sun day), Hayward Pro-Series sand filter, TF100 test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It never ceases to amaze me what some "pros" will say. These displays of complete ignorance of the chemistry is mind boggling. They should know such rudimentary things. Unreal...
    Essential Links:
