Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 115
Thread: TFPC newb in phoenix
    bper's Avatar
    May 2015
    Phx, AZ
    78
    I've owned the pool for 5 years and got sick of buying things at the pool store that I don't need while continuing to have algae and calcium issues. I have kids now ready to use the pool and knew there had to be a better way! I have come across this site a couple times in the past, but am ready to really get a handle on the water chemistry and get this pool sparkling. Just received my K2006 and will begin Saturday morning most likely. To start I thought I had pollen the last couple weeks but after further reading I'm thinking it's mustard algae (mostly on the shady sides, and on steps / sides of the pool as well as all over my vac and hoses). Plan on SLAMing and converting to bleach for my Cl. In the past I've had pucks in a floater and shocked with trichlor every week or two. Just did a pH test only as I read through how to use my test kit and it was 7.9-8.0. Need to bring that down to 7.2 before I SLAM.
    Thanks already for all the intro reading, pool school, etc. Hopefully I can contribute soon.
    ~13,000 gal freeform IG pebble (built 2006)
    Hayward S310T2 sand filter | Hayward Northstar 1.5hp pump
    Zodiac Baracuda G3 vac | Fiberstar 6008 lighting
    Taylor K-2006c
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: TFPC newb in phoenix
    Welcome! Glad you're here.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Welcome to TFP!!
    Support the site
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Oooooh...you're gonna be saving some greenbacks! Welcome to Pool School
    38,267
    Welcome to TFP!!!
    Check your CYA ... sounds like it could be VERY high which will require water replacement before anything else.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Looking forward to your first test. Welcome to team TFP.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jul 2014
    Bastrop, Louisiana
    199
    Welcome to TFP.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum and congrats on already getting your K-2006
    Casey's Avatar
    SW PA
    10,428
    Sounds like you've been reading.
    Welcome to TFP
    bper's Avatar
    May 2015
    Phx, AZ
    78
    Welcome to TFP!!!
    Thanks, CYA tests to be well over 100. Going to rent or get a harbor feight sump and remove about 65% of the water this afternoon. Fill water will be hard city water, I may need to treat for metals?
    Taylor K-2006c
    Jan 2012
    7,306
    I'm pretty sure city water should be free of metals? Perhaps unless they're picked up in old cast iron type city pipes?
    bper's Avatar
    May 2015
    Phx, AZ
    78
    Test results this morning:
    Temp 72F
    FC 0
    pH 8.0
    TA 190
    CH 690
    CYA Well over 100
    Took a sample to pool store
    TC 0
    FC 0
    pH 7.7
    TA 165
    CH 700
    CYA 115
    TDS 2100
    Langelier 0.43
    Looks like I will re-read and replace the water rather than slam this weekend
    Taylor K-2006c
    bper's Avatar
    May 2015
    Phx, AZ
    78
    High CYA, TDS Drain and Re-fill
    K2006:
    Temp 72F
    FC 0
    pH 8.0
    TA 190
    CH Over 500 (little change @ 50 drops)
    CYA Well over 100 (no dot @ ~1.8 mark)
    Pool store test:
    TC 0
    FC 0
    pH 7.7
    TA 165
    CH 700
    CYA 115
    TDS 2100
    Langelier 0.43
    For a little test kit practice and curiosity I took a look at my tap (fill) water:
    pH 7.9-8.0
    TA 140
    CH 220
    I got a HF pump and plan on draining 60-100% (Pool math says 57% for CYA, 92% for CH) but could use a little guidance. With what I assume to be mustard algae in the pool should I 1) plan on acid washing at all while lowering or just refill and SLAM? 2) I also thought maybe some bleach in a spray bottle may help to brush some of the returns and lights while the level is lowered? I considered filling while draining but will likely do them separately. Any other considerations or ideas for water replacement?
    Taylor K-2006c
    May 2014
    Franklin, NC
    9,184
    I would drain, refill and SLAM. Pay attention to the mustard directions in the SLAM article. Any extra help you want to give areas with extra brushing and cleaning can't hurt. While,I wasn't in a SLAM I pulled my light out of th niche and used the vacuum hose (it was underwater) to suck out a lot of junk form the niche. You could pull the light, clean the niche and let,the water circulate in there for a while to make sure.
    Ignore the pool store testing, especially the comments about TDS.
    Support the site
    bper's Avatar
    May 2015
    Phx, AZ
    78
    Thanks tim, draining now and I will update as I progress.
    Taylor K-2006c
    Casey's Avatar
    SW PA
    10,428
    Once you get your CYA in range of 50ppm and you start to SLAM the pool, brushing is very important as It will knock the protective biofilm off the algae and the chlorine will attack It much harder and faster than not brushing. Its a lot of work but it's necessary.
    bper's Avatar
    May 2015
    Phx, AZ
    78
    Thanks for the tip, I don't mind brushing and was doing a lot of it over the last month while I thought it was pollen rather than algae. I was suspicious though when it reappeared soon after
    I have it about 75% drained and will re-fill overnight & will test in the morning or when it's full. Should I tackle the waterline calcium now or later?
    Taylor K-2006c
    bper's Avatar
    May 2015
    Phx, AZ
    78
    Pool is re-filled (about 80-85% replacement), working on lowering pH to 7.2 and then raising CYA to 50.
    Temp 75F
    FC 0.4
    CC 0.6
    pH 8.0
    TA 150
    CH 280
    CYA <30
    Taylor K-2006c
    bper's Avatar
    May 2015
    Phx, AZ
    78
    Added 1/2 gal acid and 2 lb cya in the skimmer. For my cya poolmath I just used 30 targeting 50 as it was recommended to shoot low. Should I start running the filter 24/7? Plan on running it at least overnight to see how the cya dissolves.
    Taylor K-2006c
  20. Back To Top    #20
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by bper View Post
    Is the CYA in a sock, or just in the skimmer? Shooting a little low when adding CYA is a good idea.
    Support the site
