Thank You very much for your help thus far.
I added about half the gallon of muriatic acid (20 degree) that I purchased from lowes as you suggested. And put it in the way suggested as well.
I did all the tests again to see what changed. Here are the results:
PH: 7.5
FC: 7
CC: 0
T/A: 120
CH: 625
CYA: 85
Am I ready to go swimming ?
PH: 7.5
FC: 7
CC: 0
T/A: 120
CH: 625
CYA: 85
PoolMath only does calculations. It does not tell you what to do. That is up to you to decide (with our help for now of course )
That result is not correct. Check the volume you have entered and make sure the TA is set.
Like I said, your CYA is tolerable, unless you want to replace half the water ... figured you did not want to do that given you state's water issues.
