Results 1 to 11 of 11
Thread: Just got my Taylor FAS-DPD Test Kit
    May 2015
    covington/Ky.
    6
    Started opening my pool yesterday. It is green but clear enough to see the bottom. The ph7.6, CYA 0?, stayed clear. I have used Baking soda about 4lb. and 1 box Borax so far. I have 68% calcium Hypochlorite from last year and just bought 8.25% bleach. What should I do next?
    21500gal., IG, gunnite, freeform, cartridge, A.O.Smith Centurion pump, 14 years old, rock waterfall, 2 spa jets
    38,475
    Re: Just got my Taylor FAS-DPD Test Kit
    Welcome to TFP!!!
    Post up a full set of test results:
    FC
    CC
    pH
    TA
    CH
    CYA
    May 2015
    covington/Ky.
    6
    Fc 0
    cc 0
    ph7.6
    ta 120
    ch 150
    cya 0
    38,475
    Are those after the baking soda and borax?
    Was there CYA in the pool when you closed? Or is this a fresh fill?
    What does the water look like?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Jason, in the first post she says water is green but clear enough to see the bottom.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,475
    Well, I would put in 10ppm of FC ... wait 30 minutes and report back with the FC and CC.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    I'd start by picking up some stabilizer, aka CYA. You need enough to raise your CYA level to between 30-50, the more sun your pool gets would indicate the need for the higher level of CYA.
    Then you need to get some bleach in there pronto. You've got the CalHypo so it wouldn't hurt to use that and bump up your calcium level, but I think bleach might be a fast fix to get some chlorine in the water and start dealing with the green. You might need to perform a SLAM procedure, and you'll need bleach for that. Please read the pool school article on SLAMing your pool.
    Welcome
    May 2015
    covington/Ky.
    6
    Thanks everyone! Found your reply's late last night. Still learning my way around.
    Started SLAMing , added 3 jugs of bleach then 2.5 more an hour later. Pool looks better! Its a very light green and a little cloudy but I can still see the bottom.
    New Tests
    CF 4
    CC 1
    Ph. 7.2
    TA 110
    CH 150
    CA 0
    I am going to get the FC back to 10 and test every few hours. Do I need to run all the test every time? I will buy some stabilizer and use the Cal Hypo today.
    I also have a Hayward heater. Will the stabilizer in the skimmer harm the heater?
    The first test was after backing soda and Borax. About 1/4 of pool was fresh water. I don't know if there was any CA in last years water. I have just learned how important CA is here. I'm glad I found TFP!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Just focus on FC and CC tests for right now. I would not use cal hypo. Just stick with bleach. Test CYA in about 5 days.
    Also I don't think the stabilizer in the skimmer will harm the heater any.
    Lisa
    38,475
    I would get the CYA dissolving now as soon as you can as the sun is going to destroy the FC very quickly without it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Stabilizer in a sock in the skimmer will not harm your heater, or anything else for that matter.
