Results 1 to 9 of 9
Thread: Pool test results.... Whats wrong
    Aug 2014
    Lake Jackson,Tx. 45 miles south of Houston
    44
    13500 gallon plaster pool. Using bleach only.
    FC: 4
    CC: 0
    TC: 4
    Calcium: 200ppm
    CYA: 40
    TA: 90
    PH: 8.2
    I know I need to add acid to get the PH down but I am still getting algae forming in the pool. What may be the problem. Already cleaned the filters (DE)
    13,500 gallon pool without a spa Inground
    Pool built by previous owner in 1995 but replasterd in 2008
    DE filter (pentair FNS plus 48,Challenger 3/4 hp pump,In line chlorinator (switching to liquid bleach)
    Using TF-100 pool testing kit
    38,438
    Re: Pool test results.... Whats wrong
    If you have algae, then you need to follow the ShockLevelAndMAINTAIN Process until you pass the 3 criteria to stop. The filter is not the problem ... lack of chlorine is the problem.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Looks like Chlorine is good- with a CYA of 40, you never want to drop below 3. Ideally 5 would be a good target to allow for loss to sun. Are you dropping below 3 before you put more bleach in?
    Aug 2014
    Shallotte, NC
    693
    First, get the pH down and then SLAM. SLAM lasts until it passes the three prescribed tests. Nothing looks bad in your results, except the pH and FC. The FC will have to go quite a bit higher UNTIL the algae is gone....
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    It sound like it will be a quick SLAM
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Aug 2014
    44
    I am first going to get the PH back down and then will start the SLAM process. Printed up the SLAM instructions and will follow its suggested levels.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good deal. Just stay tight on FC residual after you're done, and you'll have no problems.
    Essential Links:
    Casey's Avatar
    SW PA
    10,453
    If it's green, you need chlorine.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    She's a poet and you better listen to her.
