Results 1 to 7 of 7
Thread: Cartridge filters, How long do they last ??
    Feb 2014
    Upstate, NY
    390
    How long would the average cartridge filter last ?? I just noticed my heater "LO" light goes on now at 2000 rpms. I tested the flow when new and I could go as low as 1700 rpms with my VS pump. Just for safety sake I increased the rpms to 2000. The pool only has been opened for two weeks now and I'm thinking the filters are dirty. The gauge on the filter doesn't indicate high pressure either. Just curious. Thx
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    38,246
    Re: Cartridge filters, How long do they last ??
    Does the gauge go to zero?
    A cartridge should last many many years before having a problem, assuming you maintain the chemistry and do not allow them to get scaled up.
    Maybe this is useful: http://www.troublefreepool.com/how-t...ter-t4465.html
    Feb 2014
    Upstate, NY
    390
    The gauge reads 3psi @ 2000 rpms and 8psi @ 3000 rpms. Thx
    38,246
    And when the pump is off, is it zero?
    You may just look for a 20-25% pressure rise up at a higher RPM to know when to clean. I would think 3000 should be high enough.
    Feb 2014
    Upstate, NY
    390
    Oh, yes yes zero when its off. The filters are only a year old as well as the pool. I was thinking when the PB laid the stamped concrete all of that powder dye stuff they use to color it went into my filter and damaged it. I did clean the filters last year. They were pretty dirty. I guess the heater can be pretty finicky when it comes to flow.
    Sep 2013
    Nashville, TN
    379
    I've cleaned my filters a couple times since we get a lot of pollen from the neighbors trees, doesn't take long and I figure it is good for the pump to have less resistance.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Feb 2014
    Upstate, NY
    390
    Thanks for the replies everyone.
