Thread: Any good way to make sure algea isn't in you pool steps ???
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    Took our steps out at the end of last season, and like other seasons I could hear water inside the step and/or rail sections.
    I put steps in our cellar over winter, but I always thought algea either is in the steps, or can grow inside the steps.
    How to prevent this, or sanatize the steps? Can anyone glean some info on this???
    deweypip
    24x54 Sharkline Matrix
    Hayward 1 hp Powermax single speed pump
    Hayward ec50ac DE filter
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Re: Any good way to make sure algea isn't in you pool steps ???
    Before I put my pool ladder back into position for the Summer I put bleach in a pump-up sprayer and shoot it into the holes in the rungs, then I shake it around. I do this a few times just to be sure anything that was in there is dead.
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    512
    Quote Originally Posted by DaneCE View Post
    That is what I do as well...and I also like to bump my chlorine up a bit those first few days when I put it back in the pool...just in case.
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    This is kind of a hard one really. If you can't keep freshly chlorinated water in them, it will be tough to prevent Algae in them if light can penetrate.
    Essential Links:
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    It is hard. Our steps have one little pin hole for a drain. I considered drilling out more holes to allow water out easily, and/or for them to dry over winter. More holes = less stregth though.
    The thought of a nursery bed for algea isn't one I'm crazy about.
    I'll have to do a combo of what you others mentioned. Get some bleach into the steps & rails, and bump up chlorine for a while after steps put back in.
    Probably the only thing you can do really....
    Thanks
