Results 1 to 9 of 9
Thread: Phosphates - Any Concern?
    Chesapeake, VA
    5
    Just had my liner replaced and getting my pool back in shape and had water test at "big name" pool supply store to check myself and to do tests I don't have. All measures in good shape (FC-4, TC-4, Salt-3100, CYA-80, pH-7.6) according to them except Phosphates @ 2500, TA @120 (coming down last 2 days & rain tomorrow) and CH @ 120.
    They hit me once before on phosphates and I spent a bunch on their product to reduce it, but see little at TFP on this as any real concern - should I worry? If so, is there a lower cost method or supply to reduce it?
    They indicate a recommended range of 200-400 for CH, but I see TFP info saying lower is OK for vinyl - any concerns?
    Thanks for any helpful advice!
    high5va
    Chesapeake, VA
    42x18 Grecian L, IG Vinyl, 33,000 gal
    Pentair FNSP60 DE Filter
    Pentair WhisperFlo 1hp WFE-4 Pump
    CircuPool RJ45 SWG
    38,275
    Re: Phosphates - Any Concern?
    Forget phosphates ... they are just hoping to make money off you.
    And low CH does not matter in a vinyl pool.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Nope, keep your numbers within our recomeded levels and ignore phosphates
    Support the site
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Snake Oil, I tell ya! You don't need to lose a bit of sleep worrying 'bout phosphates, as long as you're keeping your chlorine level high enough.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    I'd like to first off welcome you to TFP! Hope you enjoy your time here.
    As stated in this thread there is clearly no need for a member to use phosphate remover, as there simply isn't a need for it. Maintain your chlorine level and you will never have a need to worry about phosphate's.
    Casey's Avatar
    SW PA
    10,438
    Agree with everyone the phosphates is nothing to concern yourself with. And you have vinyl so don't go worrying about your calcium level. You don't need it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you maintain your free Chlorine well, Algae cannot live. If there is no Algae alive in the pool, it cannot consume phosphates for nutrients. So, your less expensive alternative is proper free Chlorine residuals. It truly is that simple. The phosphate remover is honestly a gimmick, just another product to bamboozle people with. I've never tested for them and never will. Even if I have them, and someday get a green pool, my answer to that will be the same. Free Chlorine.
    Essential Links:
    Chesapeake, VA
    5
    Thanks to all - you guys ROCK! I suspected phosphate remover was a gimmick based on their sales push pattern, then the descriptions I found here on TFP seemed to confirm and now you all have made it absolute - thanks again!
    Don't know if it is proper to call out business names here on the forum, so for any newbies - be skeptical when dealing with the largest (I believe) chain of pool supply stores in the US....I typically just use them to double check my chemistry, particularly since I don't have my own test for salt levels. Then they start spouting off about things I wasn't sure of, so I'm glad TFP is here to set the record straight. Learned my lesson.....and will send my "Phosphate" money in to support TFP !!
    CircuPool RJ45 SWG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well thanks for the support!
    We know who it is, don't worry. I will say however, trust your results. They are better, and doing the double check is pointless unless you are bored and want to see how far off they sometimes are. Go to two or more places sometime if you really want some entertainment.
    Essential Links:
