Thread: Are these tablets good to use for my pool
    May 2009
    south jersey
    49
    Calcium hypoclorite
    Active ingredients
    Calcium hypoclorite. 68%
    Inert ingredients. 32 %
    Total 100%
    Available chlorine 65%
    Vinyl pool 37,000 gallons 2hp hayward , sand filter, true L 18-41-16-28 - 9 foot deep end .. Solar panels with goldline automation ..3/4 hp polaris 380 ..BBB method
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Are these tablets good to use for my pool
    It depends. Do you need calcium in your water? Do you have a cement/gunnite pool where calcium is important? Vinyl pools or fiberglass don't need all that calcium.
    Have you considered just using liquid chlorine, such as household bleach, to chlorinate your pool?
    38,301
    Are those actually labelled for pool use?
    cal-hypo tablets tend to turn to mush and dissolve too fast without a specialized feeder ... NOT!!!! the same as the ones that use trichlor tablets
    May 2009
    south jersey
    49
    Yes they are commercial grade pool use and Do turn to mush I stopped using them just wanted to check on here if any good
    Casey's Avatar
    SW PA
    10,448
    Everything is good in moderation. But once you hit that sweet spot, you'll have to switch to something else.
    Bleach.
