Results 1 to 15 of 15
Thread: Pool filled with water from pond
    Apr 2015
    Wichita Falls, Texas
    3
    Okay here goes. We had to replace our liner this year. We are on stage 5 water restrictions. No new pool filling. We have a pond on our property and my husband, decided to completely fill our pool with water from our pond. He pumped it in, pour a bunch of algaecide into the pool and handed it over to me. I found your site, bought a Tf-100 test kit, slammed it, added DE to the sand filter and it started clearing from dark brown to a lighter shade of brown. Last night he added clear water from a rain barrel and I woke up this morning and the water is the color of dark brown rust. Help!!!!
    30 foot, 54 inch deep AG pool 1/2 HP Sta-rite pump
    Sta-Rite High rate sand filter, Stage 5 water restrictions No new pool
    filling
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Pool filled with water from pond
    Welcome to TFP!! Great that you have your test kit already. If he turned it over to you, time for him to stay away
    Did you ever add stabilizer/CYA?
    We will also need a complete set of test results.
    FC
    CC
    pH
    CYA - (ignore if you never added any)
    TA
    Any idea what algecide he used?
    I don't think you finished the SLAM. A SLAM is a continuous process until the pool is completely clear/clean, not a one or two time addition of chlorine.
    You should read the directions on SLAMing your pool in the How To section of Pool School and follow that procedure completely to the end.
    CC is 0.5 or lower;
    You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    And the water is clear.
    When all three are true, you are done SLAMing and can allow the FC to drift down to normal levels.
    Support the site
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Follow what Tim said exactly and your pool will be crystal clear. As he said it is a process and you have to have patience. Rum filter 24/7 and backwash as needed.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    well I guess a pool filled with pond water is better than an empty pool
    probably no worse than some of the pools I have seen on here that started as black and turned to sparkling clear by using the SLAM process.
    Good luck! post some pictures of day 1 so people can watch the progress.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If the algaecide you used contained copper you could be seeing metals in your water when it turned brown, this is one reason we are against the common use of algaecide, and if you must use algaecide to only use certain types. Unfortunately if it is metals there is no way to effectively remove them other than water replacement, they can however be treated with the ongoing use of sequesterants.
    Ike
    30,419
    Please post full test results from your TF-100. I filled my pool from a pond on two separate occasions.......need those test results to get started, though.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I know what ponds around there look like a lot of the time. Red dirt color. Lake Arrowhead.
    Post the results when you can, we'll be glad to help if we can.
    Essential Links:
    Casey's Avatar
    SW PA
    10,444
    Congrats on filling your new uhmmmm... Pond!
    Follow the SLAM and you'll never know it was pond water.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Don't feel bad, we're not on water restriction and my neighbor does the same thing because he's cheap. He pumps it out of the lake into the pool and runs it over a bucket full of trichlor pucks on the way into the pool. I'm a new pool owner and when I saw him filling his greenish pool I knew I needed to get pool advice elsewhere!
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by robdac View Post
    He does that in Weston? Surprised the South Florida Water Management District hasn't paid him a visit.....
    Support the site
    Sep 2014
    Fort Lauderdale, FL
    146
    I doubt SFWMD would care, to be honest. Everyone is allowed to use lake/canal water to water lawns, what difference would it make to them if someone fills their pool with it.
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
    Apr 2015
    3
    Okay I dug the "super algaecide" out the plastics bin and it does have copper, 23.9 %. And yes I did rush the slam process. I was just super excited about finding TFP. It has been storming all day so I will start slam in AM weather permitting. I have gone back to pool school and will continue diligently until I graduate. My husband has been properly chastised and kicked out of pool school. Will post test results in AM prior to SLAM and pics as well. Thank you so much and I will follow your instructions to the letter
    filling
    Casey's Avatar
    SW PA
    10,444
    Don't let a little rain deter you.
    Apr 2015
    3
    Lake Arrowhead has almost no water in it at this time red or otherwise. Boo hoo
    Actually it was the lightning and a small tornado. Just kidding
    filling
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Hey, good deal, and no worries, you can SLAM. As long as you're learning there will be someone here to help.
    Essential Links:
