Thread: Considering draining / replacing water
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Hey all,
    Last year I had to deal with the most obnoxious and worse, expensive metal problem I have had to deal with in over a dozen years. It looks like this year will be no different.
    So since I have a few weeks before the swim season is here in NY, I am really considering replacing the water. But Ive never done this before. So I have a few questions:
    - Liner pool - How much water is safe to drain at a time? Can I go a few feet below the skimmer? And lets say I do that, would 4 or 5 times doing that basically equal replacing all the water in the pool?
    - Do I need to make sure the metals are sequestered well before draining? I have to assume any metal staining on the liner, stairs, etc that I do not have floating free in the water will just be there when I refill.
    - My main drain has been disconnected for probably a decade. So the only way to drain is by pump, correct?
    Thanks so much in advance. I just dont want to be dumping sequestering chemicals in the pool every 3 days like I had to last year. We have parties all summer long and when the kids are done swimming, I like bringing the FC high up... Which eats my sequester which gets even more expensive... Its just not something I want to do anymore. Its a losing battle
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Considering draining / replacing water
    Yes, you will need to pump it out. We generally recommend 30% replacement or leave about a 1' in the shallow end.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Thanks. Do I keep metals sequestered while doing this?
    DFW, TX
    24,497
    I don't have any experience with metals or sequestrants.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by mitch08 View Post
    Yes, you want them to go with the water not sty around with the liner. I'm very conservative when pumping out water, but that is because I have a very high water table
    Support the site
    Aug 2014
    Northern IL
    4,615
    Have you tested your fill water for metals?
