Thread: Hayward Ecostar with your ThePoolCleaner question
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    Just installed ThePoolCleaner (2 wheel) on my new pool, running with 3 returns, main drain, one skimmer and one wall suction side fitting.
    In order to get the cleaner's recommended 11-13 rpm on the wheels, I needed to:
    1- run ecostar pump at 2700 rpm and
    2- close the skimmer and main drains valve on my equipment pad down to about 25% each.
    So I am finding myself either playing with opening or closing the skimmer and main down to almost zero or running pump at really high Rpms for the three hours I am running the cleaner.
    Questions: how does running skimmer and main drain at 25% capacity affect the pool, especially when the pool is running for regular circulations at 1300 rpms? (I did check and even with skimmer and main drain at 25% the pump still gets enough water even if I close the cleaner fitting cap)
    If you have a similar setup, I am curious as to what setting you are using?
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    Re: Hayward Ecostar with your ThePoolCleaner question
    Bump
    38,305
    That cleaner requires one of the lowest flow rates to work. The Ecostar is a very powerful pump. Seems odd that you have to close the floor and skimmer that much.
    I would suggest nearly closing the floor off completely to get more flow to the cleaner and skimmer.
    Running at low speed does not "affect the pool". Your skimmer may not work as well though.
