Results 1 to 7 of 7
Thread: slotted jet...why?
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    slotted jet...why?
    my pool has three returns. two of the returns are the standard eyeball type return/jets, however one of them is a slotted jet with minimal flow. What is the purpose of having this type of jet? I would like to replace it with a standard one. the other two jets push out a lot of water, very strong current.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: slotted jet...why?
    Is it there to more accurately direct the flow of water into an area of decreased circulation such as close to steps, a corner, downward in a deep end or such?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    When you say slotted are you talking about one of these venturi jets http://www.infusionpool.com/ If so they help in the mixing of water, I have one installed in my deep end to help prevent cold water settling there as I don't have a floor drain and this venturi jet shoots water down deeper than a conventional eyeball.
    Ike
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    no, it looks like this: http://www.poolzoom.com/hayward-hydr...d-sp1419a.html
    and its the jet on the opposite side of the steps, on one of the more flat areas of the pool on the shallow end. there is minimal flow coming out of it, but it is directionalized.
    Dan
    30,421
    As you can see, those fittings are easily interchangeable so try anything you like. That slot looks to me like it is intended to send water in one direction only and it makes sense that it has less volume than the others if they are conventional "eyeball" fittings
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I use regular eyeballs on some of my returns, but installed slotted ones in a couple of locations where I wanted the flow to be parallel to the pool wall. That helped me direct floating debris towards the skimmer. I don't have a flow problem with the slotted ones though, so I don't understand what you are experiencing.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    thanks, I don't have a problem with it, just didn't understand its purpose. I am gonna swap out with a standard
    Dan
