Results 1 to 7 of 7
Thread: Are my reagents still good?
    Cigar2011's Avatar
    Jun 2014
    Shohola, PA
    5
    Thank you for saving me from the pool store nonsense. I even have my kids reading this forum so they will learn the correct way of doing pool maintenance.
    In doing my research on the shelf life of my test kit I came across some interesting information.
    1. Test kit should be stored in a cool dry place.
    2. Test kits should not be allowed to freeze.
    I purchased a K2006 kit one year ago. I Stored it in the garage all year. (I can see you now head slapping yourself as you say you did what!). It Definitely froze as winter here was very cold.
    Since I broke both golden rules is there a way of telling if my kit is still good? Or
    Should I throw my hands in the air buy a whole new kit and chalk it up to a lesson learned?
    2014 Doughboy Dessert Spring 24' round 13k AGP. POWERLINE XP 1.5HP pump. 20" Aquaview Sand Filter.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Are my reagents still good?
    Welcome to TFP
    Some will be fine, some may not be. I would suggest buying a refill kit for it. The cost compared to the value it brings in protecting your pool and the people in it, is worth the relative small cost. Get a new set and be sure. Depending on the condition of your pool now, you might want to consider another kit, or extra refills.
    Essential Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Every catastrophe is also an opportunity! Upgrade to the TF-100 and keep that one in a cool, dry place!
    Isolated Spa - 345 Gallons
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    The only way to kind of check would be to run a full test and then have a pool store or better yet, two test that same water and see if the results are in the ballpark.
    Sounds like a good time to upgrade to the TF-100
    Solar Blanket, Well Water, Borax Added. 68
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would not suggest going to the pool store to verify your results. That could be more confusing than wondering if your reagents are still good.
    Essential Links:
    May 2013
    Long Island NY
    419
    You may not need all the refills in a complete test kit, you can order just what you use.you just have to do a tally and see which is cost effective.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    I left mine in the shed all winter and it froze. Some of the test were normal with what I had in the fall when i closed. However my CH test was bunk. It was reading way higher than normal, 2000. I order a new CH test, along with some others i was low on. After redoing my CH test it was 300. So I would say replace either the whole kit, or at minimum replace the test you are getting odd results from. But as some have said, it could be a chance to upgrade to the TF100.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
