Thread: Good builder in the Houston area
    Mike with South Shore Pools built my inground gunite pool this summer. The guy is older and he was one of the higher ups with one of the nation wide big builders and left them because he thought he could build a better pool with better service. He was kind of abrupt no BS kind of guy. However, he gave us more value than the 6 other builders we had out, thousands less and the pool was built using the top subs in the area in less than 3 weeks. As one sub was leaving the next one was arriving. He was onsite everyday. Not for the entire job but the guys knew he was there and it was ***** and elbows.
    His website is
    Tell him Gregg in Cypress sent you.
    My pool is about 38 x 18, 3.5'-6.4' deep, raised spa, flagstone coping, 2 skimmers, 6 returns, full steps to sunshelf, bench at deep end, water fill line, Jandy cart filter, Jandy 1.5 hp pump,Jandy valves, Jandy LXI 40000 heater, Polaris 280 with booster, white plaster, Jandy aquapure 1400 SWG, total linear ft coping is 100'.
    The other PB we had out were between $35-$45K
    Our pool was $32,500. With the tile upgrade and extra deck poured
    25,000 gallon freeform inground gunite pool with 12" raised spa. 3.5'- 6.4' deep.
    2 skimmers, 6 returns and bubbler on sunshelf.
    Jandy 1.5 hp pump, Jandy valves, Jandy CL340 cart filter, Jandy Aquapure 1400 SWG, Polaris 280 w booster, Jandy LXI 4000 heater.
    White plaster, flagstone coping, custom tan tiles with decos on raised spa.
    Pentair lights.
    650 sq ft concrete deck.
    vtowntom's Avatar
    May 2008
    Katy, TX
    Re: Good builder in the Houston area
    You got a really good deal on that pool Gregg. It looks almost exactly the same as mine which is currently being built and I paid a bit more than. Granted, we're going to have PebbleTec and we are using stacked flagstone and a few other differences.
    The pool looks great!
    Freeform 24' x 31' IG gunite, chlorine pool, 3'-4.5'-6.5' deep, 15K gallons, 8' Dia. Spa, Pentair CNC Plus 420 cartridge filter, IntelliFlo 4160 pump, WhisperFlow WF-30-2.5 HP Spa pump, Pentair .75 HP booster pump, Pentair MasterTemp 400 Heater, MDX Debris Removal system, Intellibrite Color LED lights, Tropical Breeze PebbleTec, Pentair Legend Platinum pressure side pool cleaner
