Thread: SWG or AQL-P-4 Dilemma
    Aug 2014
    Hopedale, MA
    18
    I am trying to determine if my cell is bad or my AQL-P-4 board is bad. My local pool store has tested my cell, which is 10 years old, and says it is generating chlorine (cost me $50 for the test!). The errors I get on the board say 'Check system no cell power' and 'Chlor off test salt level'. I tested the water at the pool store for salt and I used a test strip (Aquacheck test strips) and it read 3200ppm and the water temp is 62F, so the cell should start based on Goldlines manual. A few years ago I had to solder the board for the cell power issue. Any suggestions on how I can figure out which one needs replacing? Thanks.
    IG built in 2005, Vinyl, 18 x 39, 26,000 gallons, SWG Aqua T-Cell 15, timer is on for 12 hours (8 hours of sun day), Hayward Pro-Series sand filter, TF100 test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: SWG or AQL-P-4 Dilemma
    SWG is supposed to work above 60 but they don't always. I would wait until 65 or even 70 to start working on it, especially since it is so old. You definitely got your moneys worth, 10 years is a lot more than most. Use bleach for now.
    Aug 2014
    Hopedale, MA
    18
    My pool temp is now 75F and I'm still getting the 'Check system no cell power' and 'Chlor off test salt level' errors. Not sure where to go next to figure out if my Goldline 066008G-1 circuit board or my cell needs replacing. Any ideas out there?
    Aug 2014
    Hopedale, MA
    18
    HELP Please!!!! Running on bleach for past few weeks, need some advice to determine if my Goldline 066008G-1 circuit board or my T-cell 15 needs replacing. Is there any troubleshooting tests I can run?
    Aug 2014
    Hopedale, MA
    18
    More info....when I first start up the filter the Diagnostics displays amps=0.0 volts=0.0 and salt =0000ppm temp =75F for about 30 seconds and then starts displaying 'Check system no cell power' and 'Chlor off test salt level' errors.
    38,521
    Have you reviewed the threads on the bad voltage regulators? Not sure if these are the same symptoms or not.: http://www.troublefreepool.com/threa...-lights-not-on
