Results 1 to 20 of 20
Thread: Bleach
    May 2015
    Thailand
    5
    Bleach
    Hi guys,
    How much?
    How often?
    TIA!
    Intex 10' x 30" Easy Set (1,018Gal / 3,850 Ltr)
    38,262
    Re: Bleach
    Welcome to TFP!
    You need to add it daily ... How much depends on reliable test results.
    Jun 2012
    western NY
    1,559
    Re: Bleach
    Quote Originally Posted by basil View Post
    Hi guys,
    How much?
    As much as the test shows you need
    How often?
    As often as you test and it shows it is needed.
    Read the pool school section, then get back to us with any questions. We have some real good guys and gals here that can help you with this.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Bleach
    You will get to a point where you'll know based off of your pool and your cya level. Then it seems like cruise control. We need some test results from a Taylor to get started.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Jun 2012
    MA
    347
    Re: Bleach
    Like the others said you need to test. If I had to guess, I would say about 8 oz a day.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Bleach
    Hi guys,
    How much?
    How often?
    TIA!
    Welcome to the forum
    The information you are looking for your small pool is in the link below.
    http://www.troublefreepool.com/conte...emporary-pools
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Bleach
    Welcome to TFP. Chlorine level needs to be monitored and maintained daily, based on your cya level and this Chlorine CYA Chart
    Here are the Recommended Levels
    Here are the Recommended Pool Chemicals
    And use PoolMath to calculate how much.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleach
    Welcome to the forum Basil
    You need to post some water test results.
    What do you use for testing ??
    Solar Blanket, Well Water, Borax Added. 68
    DFW, TX
    24,468
    Re: Bleach
    Quote Originally Posted by Patrick_B View Post
    Hey, that's a nice little guide, I like it!
    May 2015
    Thailand
    5
    Re: Bleach
    Many thanks for all the replies.
    I'll have to spend some time reading up, you have a lot of info here.
    i am using roughly 250ml every other night, but it gets cloudy after 3-4 days & i dump/refill.
    i have never tested but i do have a pH pen somewhere... and maybe some chlorine strips.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Bleach
    Welcome to TFP! Everyone has pretty much covered everything to get you started. You really need to get a Taylor K2006 test kit to test. Strips are jus not reliable. There is also the TF 100 test kit, but since you are in Thailand I am not sure you would be able to aquire it unless you know someone in the U.S. That could ship it to you.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jul 2014
    Oakbank, Canada
    389
    Re: Bleach
    Strips are better than nothing if that is all you can get, so all the best to you. I use strips quite often, along with my test kit, and they are pretty darned close to the same. Not exact, but really close.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleach
    If it's getting cloudy that could also be a sign the water isn't really something you want to be swimming in. Not concerned with algae but with bacteria.
    How often do you need to dump the water ??
    The reason to test more often is to know the amount of chlorine in your water so you know there is enough to kill bacteria. Even more important if you have younger children or anyone with poor health.
    May 2015
    Thailand
    5
    Re: Bleach
    cheers!
    its just me & my 4 yr old. we're in the pool most days & i bleach every other night, but worry about bacteria so dump & scrub every 3-5 days (any longer & i start to see algae forming in the creases/folds)
    we have full sun for 7 hrs a day, and the ambient temp never goes lower than 25C/77F (day temp is 30-36C+/86-98F+)
    E2A - the pool came with a pump but it was pretty pointless, now im looking at an Emaux Ultra 0.12HP pump+filter combo but not sure if its going to cause me more work rather than less.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleach
    Just my opinion but I think it might be easier on you and safer for both of you if you tested the water often and kept the chlorine up at a proper level. You wouldn't need to keep dumping and refilling and the water would be clean and more importantly safe. You'd need to have the pump and filter running.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: Bleach
    If you can get reliable test results, you can then plug them into the calculator on the Pool Math tab up top and it will tell you how much bleach to use. I've been reading here a couple years but am finally cutting the pool store cord with this new pool, and I've found that pool math calculator very helpful this weekend!
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleach
    If you can get your hands on a test kit then Pool Math becomes your best friend.
    Jul 2014
    near London, UK
    37
    Re: Bleach
    Welcome to the forum Basil!
    My summer pool last year was exact same size as yours, it's a wide shallow pool so the CL loss is high at about 4-5 ppm per day when the weather is 30C
    Using the cheap 1.5% tesco value bleach we get here in the UK that's about 1.2 - 1.5 liters every day for this pool which is a lot more than you have been using although your bleach may be stronger so you would need less. As others have said poolmath is your friend....!
    Taylor kits are difficult to find outside the US, for a small Intex pool I get by with a DPD tablet kit and even an OTO kit will be fine, all of my test kits came from ebay. But you do need to test daily and make sure your CL does not drop too low
    I got fed up with cleaning cartridges daily so I got an Emaux 14" filter with 0.3HP pump, goes for several weeks without any attention at all. Biggest hassle for you will be setting up & connecting the filter to the pool but once it's done it looks after itself.
    4k gal 16' oval AGP
    Mega 1/3 HP Pump + 14" sand filter
    Palintest tablet DPD/PH/ALK - wish we could get a TF100 this side of the pond!
    Lovibond CYA
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Bleach
    Freetime, do you have any photos of that filter and pump install you can post ??
  20. Back To Top    #20
    May 2015
    Thailand
    5
    Re: Bleach
    thanks again - my tesco(lotus) bleach is 6%.
    i also have quite a lot of petals dropping in which green up pretty quick.
    im finding it hard to justify an expensive pump for a cheap pool. (plus local supplier requires 45 days for shipping...)
    i'll keep at it.
    e2a - if anyone can locate 10127 strainer plugs i would be grateful - my puppies chewed the others up and im now using home made silicon plugs which may not help with the cloudiness?
    the only sources ive found flat out refuse to ship to me here in Bkk.
