Thread: How to protect plaster step from Kreepy Krauly
    May 2014
    Austin, TX
    8
    Today I noticed that the frequent bumping of the Legend against the first step has worn down the step corner for several feet. It tends to stay there with the body (between the tires) pressed against the step until the water pressure backs off. So far, my thought about preventing further damage is to place a flat rock along the edge so that it will absorb the impact. Is there a more elegant, inexpensive solution for this problem? Moreover, as the plaster otherwise looks fine, if I can protect the edge in some way, can I expect the existing damage to deteriorate even more rapidly, or would it remain stable?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How to protect plaster step from Kreepy Krauly
    It depends on how deep it is, but most likely it will be fairly stable. Perhaps look into another Robot cleaner would be my suggestion. Or, if you can correct that action, do that, but I wouldn't risk my pool finish. Repairing it would no doubt be far more expensive than a new cleaner.
    Essential Links:
