Thread: Pentair Intellibrite light Controller Reset?
    May 2015
    AZ
    2
    I have the intellibrite 5g color LED hooked into the pantair intellitouch controller. I am unable to change the light color or light show through the settings. It there a reset procedure for the light?
    Thanks
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Pentair Intellibrite light Controller Rest?
    Did it used to work and now it doesn't? Or did it never work? If it never worked then you need to program the intellitouch to tell it that it is controlling an intellibrite.
    It is pretty well documented here:
    http://www.pentairpool.com/pdfs/inte...ntrolsysUG.pdf
    And welcome to TFP!
    May 2015
    AZ
    2
    Cool Re: Pentair Intellibrite light Controller Rest?
    I think the pool company hooked it up through auxiliary instead of through the light connections. I can change the colors if i used the switch method with the auxiliary button on/off per door choice. I will hook it up correctly and update you guys.
    thanks
    DFW, TX
    24,485
    Re: Pentair Intellibrite light Controller Reset?
    Alright! I am amazed at how many pool contractors have no understanding of automation. Not that the automation manuals make it all that easy, but still!
