Results 1 to 8 of 8
Thread: Weird question - deep end walls..
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    Obviously I should have thought of this question before I started my build. But why do concrete or gunite deep end walls go straight down and vinyl walls are sloped inwards losing square footage?
    New Build started April 2015, 20x30x40 Lagoon Style Vinyl (indigo marble/blue granite), 27,500 GAL, IG, 839 square feet, 9' tanning ledge/baja shelf, 9' radial bench, 8' classic Waterfall, 3'6" to 8'Depth, Sand, Pentair 2 speed Superflow 1 1/2 HP, SWS, 2 Pentair LED Intelibright 5 G lights, Pentair Legend Platinum II pool cleaner, 2 skimmers, 3 returns. 1080 square feet of Silver Slate stamped concrete.
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: Weird question - deep end walls..
    Hard to make a good tight corner with vinyl I reckon.
    Gunite has the structural integrity to be vertical. The slopes of vinyl liner pools are just dirt covered with a thin layer of vermiculite mix.
    Support the site
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    Quote Originally Posted by JamesW View Post
    Kind of what I was thinking, had never thought of it until now and looking at my pool, I wish it was something I considered in choosing vinyl or gunite.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Well the plus side of vinyl is the pool looks nice and big but it's less water you have to treat
    I know with mine it did surprise me when I first swept it how the sides go down a bit and then angle to the bottom. That and how the steps flex under your foot getting in an out.
    Solar Blanket, Well Water, Borax Added. 76°
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    True! Less water is a positive but hoping not to hit my head diving too lol
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Quote Originally Posted by karynkjd View Post
    You pool is slightly larger than mine, it's probably Type 3 (water invelope, see http://www.srsmith.com/media/47241/0...i-standard.pdf), so you will be fine with diving. Also sloped walls give extra fun element for kids or adults just to hang out on the deep end.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    That's what my best friend said today! Thank
