Results 1 to 15 of 15
Thread: In NEED of HELP PLEASE
    Mar 2015
    St. Pauls, NC
    8
    My pool water is clear, I can see the bottom...but it seems to have a stinky kinda smell to the water and even can smell it on my hands (I haven't been in the pool yet). TC=8, FC=10, pH=7.8, TA=120, CYA=100 Temp=72. Plz tell me what I need to do?
    Marie
    Intex AG 22' X 52", 14470 gal, Sandpro 50 sand filter, Krystal Clear SWG, Intex over the wall skimmer, Smart Pool automatic cleaner
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: In NEED of HELP PLEASE
    I wish I had an answer. I know there was a post about a fish smell someone posted.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mar 2015
    St. Pauls, NC
    8
    If anyone else can tell me what I need to do, I'd appreciate it.
    Marie
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    Quote Originally Posted by RMB View Post
    That was me with the smelly water and its been coming and going. I notice your FC number is much higher than your TC - you using test strips? Describe the smell. Mine is sort of like fishy chlorine. Smells a lot like dichlor actually. I noticed running my spa in spa mode made it a bit better since it only uses the suction from the spa in that mode, otherwise its all pool.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    30,414
    How long has it had this odor? Have you kept your chlorine up around the current level during this time?
    Dec 2014
    West Hills, CA
    157
    is it a metallic smell? fishy or rotting smell? chlorine smell? definitely need more info on the nature of it. also, make sure all your filters are clean, skimmer and pump baskets, vac leaf catcher if you have one. anything rotting in there might cause a smell.
    Mar 2015
    St. Pauls, NC
    8
    yes using test strips. and yeah it kinda smells like fishy chlorine
    I opened my pool a month ago and it has had a odor pretty much the whole time
    everything was cleaned and put up for the winter, and I just hooked it all back up. the water stayed in the pool during the winter, but I winterized it. smells more like a fish pond odor
    I was tempted to let all of the water out and start over cause it didn't smell that way last year.
    Marie
    Dec 2014
    West Hills, CA
    157
    well, im still kinda guessing at what the smell was coming from as it comes and goes. right when i think i've figured it out, it comes back. i notice my tap water kinda has the same scent and i think the addition of chlorine just increases it - but then, like i said, made sure every filter was clean and ran water through my spa, and it seemed to dissipate to quite a low level. didnt smell anything at all this morning, but last week was gross, could smell it in the house. i think im hypersensitve to the smell now though, so that doesnt help! no one really had a solution. you really should get a real test kit, i was using strips, still do on occasion but certain strip readings are just downright inaccurate to a scary degree. its so fast to test just chlorine and ph, and the rest of the tests you don't do every day.
    Mar 2015
    St. Pauls, NC
    8
    The chlorine didn't go up THAT high till I did the Borax, and Muriatic Acid
    Marie
    Dec 2014
    West Hills, CA
    157
    before you drain, just test the water with a reliable kit. it will give you a far better picture of what is happening in your water and what you need to do to fix it. we don't winterize in SoCal so i really don't know whats involved other than a lot of people here on this site opening to all sorts of interesting problems.
    30,414
    chlorine will fix your pool. Run your chlorine up to maybe 20 ppm or so and hold it there for a day or so. The smell should go away.
    I know you didn't ask but your CYA is too high to manage your pool properly. I would suggest a 50% drain to get you CYA down to 50 ppm. Of course, that assumes the test strips are correct and that is a really big assumption.
    As you read through the forum, you will find we don't advocate the use of pool store testing or test strips. You should consider getting your own GOOD kit and taking charge of your pool./
    Mar 2015
    St. Pauls, NC
    8
    OK I will get a test kit. I will let the water out to get the CYA down THEN how much bleach will I need to make it 20ppm?
    Marie
    Dec 2014
    West Hills, CA
    157
    again, get a test kit and test it before you drain. ESPECIALLY free and combined chlorine with the FAS-DPD test. that will tell you if something organic is eating your chlorine and possibly causing an odor. @duraleigh, the pool should be at 80CYA as he has a SWG so its not really THAT bad, however, the shock level of chlorine is pretty high to deal with a SLAM at 100...IF its truly 100 and not more.
    I know its kinda crazy - but those strips are really pretty bad - it never gets my ph right. think about it, how can your free chlorine be MORE than your total chlorine? if your CYA reading is wrong, then you could be THINKING you're at SLAM level and you really won't be so you'll just be dumping money and time for no good reason.
    Dec 2014
    West Hills, CA
    157
    http://www.troublefreepool.com/calc.html
    the pool calculator is the best. check it out. i especially like the "Effects of Adding Chemicals" part.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP.
    You are not maintaining enough chlorine for your high CYA, based on the Chlorine CYA Chart, you need to be aiming for 12+ to keep algae from growing. Good that you are going to do a partial drain to reduce CYA.
    Here are two introductory articles in Pool School.
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    This lists the Recommended Levels for your pool.
    Here are the Recommended Pool Chemicals to maintain your pool.
    And use PoolMath to determine how much to add to reach the desired goal.
