Results 1 to 8 of 8
Thread: Replacing a Pool Pump or Motor Advice
    May 2015
    kilgore, tx
    4
    I have a 25,000 gallon outdoor inground pool that has a Magnetek EPlus 1.5 horsepower pool pump. I am told that the motor is out on the pump. Am I better off replacing the entire pool pump and not just the motor as I have added a fountain in the pool and would like more water flow through the fountain?
    And any recommendations on what to replace the existing pool pump with, i.e. brand and model number and would a 3 horsepower pump be sufficient for my pool?
    Thanks
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Replacing a Pool Pump or Motor Advice
    I would suggest just the motor, and probably go with a 2 speed motor, assuming this pump was working ok for you otherwise. In general it is my experience that most pump bodies will last through about 3 motors before needing to be replaced.
    Jul 2007
    Suwanee, GA
    528
    You'll likely have to stay with a 1.5 HP motor of you replace just the motor. If you choose to replace the entire pump, I'd agree with Isacc-1 that a 2 speed motor may suite your needs better.
    Careful going too large on the pump though, a 3HP may exceed the sizing of your plumbing. A pic of the pump/plumbing would help.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    May 2015
    kilgore, tx
    4
    I'm sorry - I am having a hard time posting a picture. When I try to insert image, it keeps telling me failed. Picture size is 2.02MB. Any suggestions on how to insert a picture of the plumbing? Thanks
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Use photobucket.com just upload pic there and copy the IMG code the paste it here.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Lisa hit the nail on the head. Here is the Posting Photo Tutorial
    Support the site
    May 2015
    kilgore, tx
    4
    Thanks for the help. Here is the link to the picture of the existing pump. Hopefully this shows the plumbing...
    May 2015
    kilgore, tx
    4
    Can anyone tell if a 3hp pump will work with the plumbing in the above picture? Thanks
