Thread: Is there a trick to get Hayward cover off wall skimmer?
    Ok, I've tried everything I know?
    The cover for the Hayward wall skimmer is hard to open.
    I've tried very fine sand paper, silicone o-ring lube (which seem to work well but attracts sand which makes it worse)
    Is there a tip or trick to allow this bugger to slide open easier?
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
    Jul 2014
    Bastrop, Louisiana
    199
    Re: Is there a trick to get Hayward cover off wall skimmer?
    When I need something lubricated but not to attract dust or sand, i use paste wax. might be worth a try.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
