Results 1 to 10 of 10
Thread: Tested water with TF-100, recommendations from here.
    Water Temp 75
    FC 2
    CC 0
    TA 80
    CH 70
    CYA 20-30 added eight pounds 3-4 days ago, finally starting to register.
    pH 6.8
    Thanks!
    18x37 IG 22,500 gallons...Vinyl Liner...Hayward EC-65 DE Filter...Hayward 1HP Super Pump...Aquarite SWG...TF-100 test kit.
    38,475
    Re: Tested water with TF-100, recommendations from here.
    What do you think you should do? After all you have been a member here for 7 years
    Why don't you lay out your plan forward and we confirm or deny
    I've been a lurker for years but never really embraced the BBB method. Looking to do this more on my own without pool store help. Looking for support from the forum.
    30,431
    jblizzle is embracing our concept as a teaching forum so let's get you started.
    You dosed enough CYA to get to 40 ppm. I think you added that much on purpose by using poolmath, right?
    Next step is to get your other parameters into correct ranges.....how does your water look?
    I used 8 pounds on pool store recommendation, haven't played much with the calculator to be comfortable with using it yet. Water looks nice and clear!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    The calculator is fairly easy and straight forward. Open it in another tab and start plugging in your numbers. You can look up your goals on the Recommended Levels Chart.
    We really want you to take control, but you can't really do that without working things out in your mind.
    Also, when adding things to the pool water - especially CYA it's best to do it in smaller stages so you don't overshoot your goal.
    Support the site
    30,431
    Since your water is nice and clear, there is no reason to SLAM at this point. All you need to do is bring your parameters within the guidelines we suggest in Pool School.
    There is no ABSOLUTE order but pH is a good place to start. Your pH is a little outside the guidelines we suggest. read "The ABC's of Pool Water Chemistry" up in Pool School......it'll tell you the correct range for pH and it will also tell you how to raise it. Now, you can go to PoolMath and it will tell you how much (20 mule team borax) to raise it the correct amount. Make sense?
    Yes, messing with the calculator now. Seems pretty straight forward. Thanks for all the suggestions!
    38,475
    I had a feeling that you might know more than you think you know.
    I mean you have a TF-100, so clearly you have done at least some learning here over the years.
    I much prefer for someone to lay out what they think they should do and then we can offer corrections or confirmations. For one, it is easy and quicker for us responders to do that. And second, it proves that you are thinking about what you need to do and obviously trying to learn.
    It is not nearly as hard as you may think it is.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Here, I'll point you in the right direction. Although, bliz playing obi wan is awesome!
    TFPC for Beginners
    Recommended Levels
    Recommended Pool Chemicals
