Results 1 to 13 of 13
Thread: New AGP with Aqua Smarte mineral system
    May 2015
    Cincinnati Ohio
    4
    Our 27' AGP just hit its fill mark and the electrician will be out tomorrow to run the line for the pump. We have the Aqua Smarte Plus docking station mineral system. Maybe I am missing something on the PoolMath calculator but I don't see a way to use the calculator with this system to keep the FC between .5 and 1.0 PPM as the Aqua Smarte system recommends
    Eric
    27' Round Sentinelle-Quantum above ground 18,500 gallons, Aqua Smarte Plus Docking Station, Ecco 1.5 2 speed pump and cartridge filter system
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New AGP with Aqua Smarte mineral system
    That is because we don't recommend mineral systems.
    First, they add "minerals" that we call metals to the water that you really don't want. Copper is the most common and it can end up staining your pool or coloring your blonde friends hair green.
    Second, most are way too expensive.
    Third, it's just easier to test and only add to the water what it needs, when it needs it. Check out How to Chlorinate Your Pool
    Welcome to TFP
    Support the site
    May 2015
    Cincinnati Ohio
    4
    Thank you for the information. Once the free packs are gone can I just not insert the packs and leave the system as is and follow the guidelines on here?
    Eric
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Cincybuckfan06 View Post
    You could, but each of those free packs is adding metals to your water that may cause problems later. To follow the pool care methods taught here you need to arm yourself with the knowledge and tools necessary to care for your pool.
    The knowledge is condensed in the Pool School link at the top of every page. It is a great community here, but we do ask that you read and try to understand the information being taught. Questions are always welcome and folks will try to direct you and teach you the methods.
    The tools are not limited to the brushes, vacuum hoses and other stuff you use around the pool, but include the most important item - one of the recommended test kits. You can buy a kit at a pool store, but again the pool store kits generally won't cut it. To effectively practice the TFPC methods, the FAS/DPD chlorine test is essential. All these kits contain that test while very few other kits do. Think of it this way, do you see a doctor blindly prescribing drugs without seeing the patient or having tests run? Here at TFP we are going to ask for photos so we can see the condition of the water and are going to ask for a full set of test results.
    Support the site
    Jul 2007
    Suwanee, GA
    528
    Since you're new at this, I know it may be difficult to listen to a complete stranger on the internet. Do a few searches on this forum and you'll find many that have used the mineral systems and have since left them behind.
    http://www.troublefreepool.com/threa...arte-system-or
    I found TFP while my pool was being built, I follow the recommended guidelines and have never had problems maintaining the pool. I spend very little time maintaining the pool and maybe $100 a year in chemicals, majority on muriatic acid.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    May 2015
    Carbondale, PA
    17
    My pool has a pool frog system installed. I spoke with the previous owners about what they were spending monthly on pool maintenance. Yeah, no. For a system that was supposed to make pool care easy and "cheaper", they sure did spend a lot of time and money on maintaining it. I'm talking over a hundred bucks a visit to the pool store every month. And she said with paying someone to open at the beginning of the season and then closing she was adding another 3-400 to that bill. So she was talking about 6-700 a pool season to open/run/close. No thank you! I closed it last year after reading up on stuff. Opened to a pretty dang clear pool and have added 3 bottles if bleach to do an overnight test. They cost me 9 bucks at SAMs Club. Think I'll stick with this method!
    27 foot round 4ft deep AG vinyl. Hayward Sand Filter.
    Dr. Wellness Lifestyle x-12 spa.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    +1 that a troublefree pool is cheap and easy to maintain!
    May 2015
    Cincinnati Ohio
    4
    Thank you for the comments!
    Eric
    Casey's Avatar
    SW PA
    10,444
    Welcome Cincybuck. You will not regret ditching the mineral system and going with TFPC. The TF100 is an amazing kit and super simple to use. The speed stir is pretty awesome too.
    May 2015
    Cincinnati Ohio
    4
    We are family new to owning a pool so this is all very Greek to us. I am going to Pool school at Watsons this Saturday so I hope t have a lot of questions answered then.
    Eric
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    i would avoid going to a pool school put on by a pool store. 95% of the problems new people post on here are due to the information given to them by the pool store. your better bet is to read the pool school articles here and ask questions.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2013
    Seguin TX
    192
    TFP Setup is cheap and easy, at least for me, I have only added bleach and cya to my pool. It is nice and clean and the water does not burn the eyes .
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    I think I found a print out online of the Watson's Pool School notes....avoid!
    summary: liquid chlorine not recommended since its not stabilized, tricholor and pucks are a must, pumps must run 24 hrs a day. the recommended way to clean a green pool...add yellow out, chlorine pucks, something called "pool first aid" and copper algaecide.
    basically they are everything that TFP advises against.
    hmm...I also see they offer discounts on these chemicals at the seminar that they are going to tell you you need.
    sounds like one of those timeshare scams, haha
    Dan
