Thread: Low PH High Chlorine
    How long does it take to damage a liner with high Chlorine and Low PH? Put another way how long do you have to correct the balance before it's too late?
    Glenn - Pickering, Ontario
    Circa 1980 Vinyl In-ground 80,000 Ltrs. ~ K2006 Kit ~ Hayward Pump/Navigator/Sand Filter ~ Raypak 255 Gas Heater
    38,290
    Re: Low PH High Chlorine
    Too late for what exactly?
    The longer the bad chemistry conditions exists, the more damage you are doing.
    That totally depends on how out of range your levels are. A little out of range is rarely an issue. The further out of range you go, the more quickly there is an issue.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    Do you have a science experiment going?
