Thread: temporary decking / patio for new build
    Nectarologist's Avatar
    Apr 2015
    New York
    427
    Hello. What have you used for temporary decking / patio around your new in ground? Of course I have all dirt now and was thinking of using 2'x8' plywood covered with turf/grass carpet so I can go from my deck to the pool without getting our feet (and the pool) muddy. I didn't see this covered but maybe temp decking / patio is not the best terminology to use. I'll be doing 2'x2' tech block squares (2 side by side) and grass all around next year but it's dirt/mud for now. Thanks in advance for the help.
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    Re: temporary decking / patio for new build
    I think I might be tempted to smooth out the dirt and use the astroturf without the plywood. I'm not sure that plywood would hold up well enough without delaminating.
    Jul 2007
    Suwanee, GA
    528
    Marine grade ply would hold up better at 80 a sheet. How about a pic so we know what we're dealing with?
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Jun 2013
    Southwick, MA
    211
    Use cheap paver stones, 8X16 would work well.
    24X44 IG Vinyl Custom Shaped Pool, Starite S7M400 Cartridge Filter, Starite Sumpermax VS Pump, built July 2015, TF-100 Test Kit, Pentair Intellichlor IC40 SWG, NG Starite SR400 Heater, Easytouch with Screen Logic, Magicstream Laminars, Bullfrog A7 Spa
    MJF54's Avatar
    Jul 2014
    Southeast, WI
    30
    wood pallets with the plywood and turf on top?
    Mike F.
    15' Above Ground Sharkline Matrix, Vinyl, 6,000 gal. Hayward XStream Cartridge Filter. TFT 50 Test Kit. Install 7/2014
    Raypack 150k BTU Natural Gas Heater installed 6-2016
    Apr 2015
    New York
    427
    As an update to others who may be wondering. I wound up putting a piece of plywood (cheapest 3/8 at Lowes) and then placed an out door carpet I had on top. Worked fine for the summer and I'll have the area filled in for next season.
    Thank you for the ideas.
