Thread: Whats the deal with winter "Stain-Away"?
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    I was planning on simply balancing my water, shocking it and maybe adding a bit of Poly 60 for the winter.
    Now I saw that the winterizing kit sold at the pool stores also include a "stain preventer" (stain away?) to protect the liner during the winter.
    Is that anything necessary or is it just homeopathy for pools?
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    Re: Whats the deal with winter "Stain-Away"?
    If your pool has metals in the water you often need to add something to help hold the metals in solution over the winter. If you don't already have a known metals problem then I wouldn't worry about it.
