Thread: Sandy Bottom
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    Sandy Bottom
    Would having air in my lines cause the sand from my filter to blow out the jet?
    2017 bahama spa - serenity cove 82x82x39 stainless steel jets, 325 gallons,plasma ozone purification system,4kW heater, 2 pumps 6bhp each, acrylic surface TFtestKits TF-100 http://tftestkits.net.
    38,508
    Re: Sandy Bottom
    Welcome to TFP!!!
    Nope. Sounds like 2 different problems.
    1. You should not have air in your lines ... points to a suction side leak
    2. Sand should not enter the pool ... points to a problem in the filter or backwash valve.
    wbowlin1's Avatar
    Apr 2015
    Jackson Tn
    20
    Re: Sandy Bottom
    While looking into the filter for the problem, I found only 3 of the 8 laterals were attached to the hub. Also less than half a bag of sand left in the filter. Thank you for the guidance on my first problem. Now on to the new Since taking the plumbing off the filter, I now have to replumb. Are there any special pipes, glue, silicone that I will need?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Sandy Bottom
    If PVC piping, just a kit of primer and glue that comes together in a pack.
