Results 1 to 7 of 7
Thread: SWG over sizing good or bad..?
    Mar 2015
    Port Neches, Texas
    12
    I have a new 30'x54" AG 20k gallon pool I am installing. I live in Texas where it's hot and sunny with extended pool seasons. As for as equipment we bought a Hayward C3030 cartridge filter and the Pentair SuperFlo VS. I've been on the fence with the SWG selection but I am about to pull the trigger and go with CircuPool SI-45 plus. Is there any negatives to having an over sized swg?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: SWG over sizing good or bad..?
    Yes, oversized is recommended. Get one rated at least twice your pool volume.
    Check out Salt Water Chlorine Generators
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    What Tim Said.
    If you get a oversized swg cell, for example a 40K vs a 20K, you can run it at 1/2 the output to achieve the same FC, which means it should last twice as long.
    the little attitional cost of the upgraded size isnt all that significant when compared to replacing the small cell twice as often as the larger one.
    Divin Dave,
    Mar 2015
    Port Neches, Texas
    12
    Thanks for info guys. That's is exactly what I was thinking in terms of how much less the larger cell would have to be driven to achieve the same output as as smaller cell so I figured it would a little longer.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Glad we could help !
    Divin Dave,
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Look at this site too:
    http://discountsaltpool.com/Salt-System-Comparison.php
    They are still doing the free upgrade on Circupool brand generators. You could buy one of the 30 series and get upgraded to the bigger 45 series.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    Mar 2015
    Port Neches, Texas
    12
    Quote Originally Posted by Propbndr View Post
    This is the site I ordered from, I bought SI-45 plus last night.
