Results 1 to 18 of 18
Thread: solar panel heater / distance question
    Feb 2014
    Central Jersey
    12
    Hey all, without getting too technical I was hoping to get some basic feedback on my solar panel heaters for my pool. I read through a lot of "hydraulics 101" sticky and will probably have to read a few more times for it to make sense to me.
    Anyhow, I am in very early stages of "pool anything" at this point but need to come up with a plan in preparation of pool opening at end of this month. I have a 21 round AG with a cartridge filter and I purchased two solar panels (2'x20' each) last summer. I had them laid out on the ground over a retaining wall about 3 feet high near the pool and they worked great for about half the summer, around August the path of the sun ends up on the other side of my neighbors fence instead of directly over my yard and therefore shading my panels instead of heating them. So ideally these panels need to go up on my roof because it gets sun from dawn till dusk so long as its sunny out.
    ok so initially I thought I would run hoses to and from the panels on the roof and we are talking about 100 feet each way. My house is only one level so its not much of a climb but after reading the Hydraulics 101 I noticed no mention of using hose so I think its safe to assume that its not a practical means of running water for this purpose so pipes are the way to go, correct?
    Ok now my other thought was my pump and is it strong enough to push all through roughly 200 + feet of pipes and hoses. Its a no name pump purchased with a pool package at my local "At Home Recreation" store. I don't have the actual specs for it at the moment but I recall the pump says its a 1.5 HP. Last summer I noticed a considerable loss of pressure on the return whenever I had the heaters on versus off. It was still strong enough to rotate the water, eventually, if no one was in the pool but a no where near as strong as when the heaters were off. So if return pressure was so weak with roughly 20 feet of hose will a 1.5hp pump be enough to push this water all the way through or was my set up wrong?
    Set up was basically one hose coming from filter and into a PVC splitter with a valve and then connected to two more hoses. one went towards the the heaters and the other went to the return jet. Actually both the heaters return hose and the regular return hose were connected via PVC yet again about 4ft prior to the hose that connects to the return jet. and the heater return line had a one way valve before joining the other return line so as to keep water from going to the heaters when I wasn't using the heaters but I think it was defective as when the heaters were shut off I could still see leaks coming from the panels. Only time the leaks would stop is when pump was off.
    If I have to invest in a name brand pump I will bite the bullet and do so because being in Central Jersey these summers are hit or miss but I'm wondering if my pump is sufficient enough and maybe with some guidance I can put something together that will actually work because it seems like last years set up was not quite right. Thanks in advance for any feedback/suggestions on how to get this project going properly.
    38,521
    Re: solar panel heater / distance question
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Moving the water long distances, you will want to use a larger pipe, preferably at least 2" hard PVC. Hard to say if the pump you have will have enough power to raise the water to your roof or not without more details.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hose is too small. (lost of restriction/low flow rates) You'll want at least a minimum of 1.5" or greater.
    Feb 2014
    Central Jersey
    12
    ok this is the pump filter that I have.
    http://www.athomerecreation.net/sl-1...f-w15-hp-13605
    The following is the specs from the website.
    This 150 Sq Ft Black Diamond Cartridge Filter with 1.5 Hp pump and motor comes with a high capacity reinforced cartridge designed for efficiency and dependability. 1.5 threaded ports
    Hose fitting
    1- 3 Molded pressure hose with union ends
    2- 6 Connection hoses
    Easy twist off lid
    2- isolation valves
    Built-in check valve
    Clamps
    Drain Plug
    Base
    9,750 gallon
    AG 21' round
    Cartidge Filter
    Sl 150 Black Diamond Cf W / 1 . 5 Hp
    Pool package from local AtHomeRecreation.net
    38,521
    We would need to see the pump performance curves to know how powerful the pump is.
    Feb 2014
    Central Jersey
    12
    How would I go about figuring that out?
    9,750 gallon
    AG 21' round
    Cartidge Filter
    38,521
    Most major brands publish them on their websites ... no idea about this brand.
    Feb 2014
    Central Jersey
    12
    ok, I'll pay my local pool store a visit and see if they can provide some detailed specs on this pump. I'm not too confident in their honesty as I've caught them trying to sell me a bunch of **** I don't need but I do know that it does a very good job when there aren't "extras" attached to it.
    But say I did want to purchase a new pump. Any recommendations on what brand / type in order to accomplish setting my heaters on roof through roughly 200 feet of pipe? Thanks.
    9,750 gallon
    AG 21' round
    Cartidge Filter
    Feb 2014
    Central Jersey
    12
    Ok so I contact the store and here is what they sent me. Mine being the 1.5hp unit
    9,750 gallon
    AG 21' round
    Cartidge Filter
    38,521
    That is significantly weaker than my 1HP pump that I use for my solar array; although it might work. You only need about 8-10GPM to feed your 80 sqft of solar.
    I think I would just plumb it up and see if it works. You may not need or want all the flow going to the solar anyway.
    If it does not fill the solar with adequate floe, then you will need to get a more powerful pump.
    Feb 2014
    Central Jersey
    12
    Should all pipes be same size or should I go with a slightly smaller width on the return side? would 1-1/2" do? Or should I go bigger. Because if this doesn't work with my current pump I see a few different Haywards on Amazon that I can pick up in the $200 range. I just dont want to lay pipe and then if I have to change the pump find out I need to start from scratch again.
    9,750 gallon
    AG 21' round
    Cartidge Filter
    38,521
    Use 2" pipe everywhere that you are adding/changing pipe. No problem though if there is smaller pipe where you are not doing any plumbing. For that long run you want larger pipe.
    If the current pump does not work, then you would just have to change the pump connections, hardly starting from scratch.
    Feb 2014
    Central Jersey
    12
    2" pipe is doable for the budget. What exactly do you mean by "No problem though if there is smaller pipe where you are not doing any plumbing"? I guess I'm confused as to what you mean by "plumbing"? Isnt the act of setting all this up "plumbing"? Thanks.
    9,750 gallon
    AG 21' round
    Cartidge Filter
    38,521
    I mean if you have 1.5" pipes between the pool and pump or pump to filter, etc it is still fine and recommended to use the 2" wherever you make changes. But, not required to redo anything that is smaller.
    Feb 2014
    Central Jersey
    12
    ok now I understand. Currently I mainly have pool hoses. The only pipes i currently have are actually wye's for splitting flow to heater and then back into main return.
    Alright I think I have a game plan now. Thanks for all the feedback. Much appreciated.
    9,750 gallon
    AG 21' round
    Cartidge Filter
    38,521
    Getting rid of the hoses would we a major improvement actually and could help the pump be enough for the solar.
    Feb 2014
    Central Jersey
    12
    Ok so I haven't ran pipe up to my roof just yet for the heaters. I wanted to top off my pool and get it running asap before I spent time on the heaters. In the meantime I did replace my hoses with pipe only I quickly discovered plumbing isn't as simple as I thought. I finally turned on the pool last night only to discover leaks everywhere.
    First thing I noticed as soon as I removed my aquadoor from my skimmer plate is that my skimmer is cracked. Itís a hairline crack, on the bottom of the bucket, barely noticeable but there is slow drip coming from it. Should I be concerned with this? I mean I know it has to be replaced but after just topping off the pool I would rather not lower the water again to replace the skimmer if I can get away with waiting till next spring.
    Next is my **** plumbing job. It seems I have leaks coming out of both ends of every union. Any tips on how to get the leaks to stop or should I just let them be? Itís not gushing out, they are slow drips and don't know what affect if any this has on my system. Personally I rather not see anything dripping but if itís not a big deal I guess I can live with it.
    I tried uploading pics but it seems I am out of space on this site and cant figure out how to delete pics out of the upload manager.
    9,750 gallon
    AG 21' round
    Cartidge Filter
    38,521
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    How did you do the plumbing? Sounds like something in your process must not have been correct for that many leaks.
