Results 1 to 8 of 8
Thread: New to ALL this...
    May 2015
    Avon, IN
    23
    New to ALL this...
    Just a couple quick questions here....I'm waiting on my testing kit... (Taylor K-2006). In the meantime, I have chlorine tabs in my chlorinator - is this a NO-NO? My pool is currently cloudy and has been since opening. I can at least SEE the bottom now (after lots of $$$ spent at the pool store). I am sure I'm going to have to SLAM the pool (which makes me nervous). I've read and read and read on this site and THINK I'm ready for this.... I'm ready to try anything that will clear my pool up.
    On my TEST STRIPS I have now (I know they aren't accurate - waiting on my kit), my numbers are:
    FC 5
    pH 7.2 (this one is questionable....)
    CYA 0
    I forget the others - I know this isn't complete and may not be helpful to anyone at all - I'm just trying to figure out if there is anything I can really do while waiting on my test kit... and wondering about the chlorine pucks.
    Any help is appreciated...I'll post specific numbers when I get my kit - delivery is estimated Friday - Tuesday sometime. Long time to wait....
    Thanks!
    18,000 gal; inground; vinyl; 18' x 36'; Cristal-Flo Sand Filter (new sand 4/27/15); Taylor K-2006 test kit; Avon, Indiana
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: New to ALL this...
    Hi,
    Welcome to TFP.
    1st, the thing we dont like about chlorine pucks, is using them as the primary source for chlorine. They add chlorine which is a good thing, but they also add either Stabilizer at the same time. If used for too long, the build up of CYA over time will become problematic.
    Using pucks on an occasional basis may be ok. Lots of us do it. They key is knowing when you can and when you cant.
    And you can learn that right here.
    As for your SLAM. Dont be nervous. It really is not difficult to do. You will want to do the following.
    Test the water
    Add CYA if necessary, to get it up to about 30. If CYA is above 80, then drain half the water to get the CYA down.
    Next, adjust your Ph to 7.2.
    Next add enough liquid chlorine to get you to SLAM level. the SLAM FC will be based upon your CYA level.
    MAINTAIN the slam chlorine level. The more often you can keep the FC at SLAM, the quicker it will go.
    Thats really all there is to it.
    Divin Dave,
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome. If your CYA is 0 you need to get it up to at least 30 to do a SLAM. I would wait for your test kit to arrive unless you know someone who has a reliable test. The strips just don't cut it.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have some questions if you dont mind.
    Do you know how to properly add CYA?
    Do you know how to use Pool Math?
    Have you found the FC/CYA chart?
    Have you found the proper SLAM Instructions?
    If not, pipe up, and I bet money Azgirl can fix you up with links to all of them!
    Divin Dave,
    May 2015
    Avon, IN
    23
    Yes! I've read about ALL that on here...you've all taught me well so far! Just waiting on the kit and anxious to get started...I even have 10 gallons of bleach, some baking soda, and Borax on hand too! Only thing I don't have is the CYA - which I'm assuming I get at the pool store and it's labeled clarifier? That would be the only question I have thus far that hasn't already been answered...
    THANK YOU!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by Divin Dave View Post
    Yes I can! Looks like she has them.
    Quote Originally Posted by amontgo94 View Post
    THANK YOU!
    You can either get stabilizer at the pool store or you can get it at Walmart. They have HTH brand for family cheap.
    Lisa
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    CYA is known as STABILIZER or Stabilizer and Conditioner.
    We dont recommend using clarifyer. If your pool is maintained properly, you wont need it. On top of that, some of the clairfiers on the market can horribly clog a filter if the conditions are right.
    THANK YOU!
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I buy my CYA at Lowes on the pool stuff aisle. It is labeled stabilizer, made by Kemtek.
