Thread: peeling vinyl liner above waterline
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Starting our 10th season of pool use with a vinyl AGP liner. Below the top rails but above the water line there is what looks like the top layer of the liner is peeling. There is no hole in the liner, nor is it ripping.
    I recall using a "mr. clean magic eraser" last year and I think it was in that area. When I noticed the "eraser" turning light blue (which is the liner color) I stopped using it, realizing the "eraser" is more like a fine steel wool. Others have sworn by it for cleaning.
    Has anyone ever used it and noticed their liner starting to peel?
    I'm thinking the liner will hold up this year (as long as I don't use a "magic liner tearer . . . oh I mean eraser"
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Re: peeling vinyl liner above waterline
    bump
    any thoughts?
