Results 1 to 14 of 14
Thread: Trouble Reading PH Color
    Jan 2013
    Friendswood, TX
    320
    So I have been having trouble reading the ph color for a while. I can tell if it is in the orange range or the pick range but when it's the 7.5-7.7 it's hard for me to tell.
    Is there a way to determine PH like the chlorine test where you look for it to go clear?
    If not, what is a good recommended ph handheld tester? I don't mind spending the money to make sure I don't have a ph issue.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Trouble Reading PH Color
    It's a fairly frequent question. I've been considering a MyronL PT2. If you look on Taylor's (Taylor Technologies) website. They sell it for about $100. I know this brand well, and have heard good things about these from others in my industry. As a rule, inexpensive pH meters are problematic. Experience has taught me this as well.
    Essential Links:
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    You can try using 4 drops or even 6. It does not change the color of the sample, just the saturation of the color. I have a much easier time using 4 drops. You can also take a piece of thin white cardstock (business card can work), and cut a slot in the side of it so you can compare the sample to the scale one at a time. That makes it easier than looking at the sample and all 5 color scales at the same time.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Mar 2015
    Harvey, LA
    300
    Patrick, about the PT2, is it impaired in the same way as the strips/drops in that it doesn't work well with high FC counts?
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Jan 2013
    Friendswood, TX
    320
    LaMotte seems to have a lot of pocket ph testers as well.
    ~Paul
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by gilbee View Post
    No, it wouldn't be. One thing though, is that they need care and attention to perform consistently. So you have to keep calibaration solutions on hand. No big deal, but it is critical. They also have to be stored with the tip where it never dries out. These like others will come with a storage cap to ensure that they stay wet. Stored for the off season, you'd want to get it out frequently (every couple of weeks at most) to make certain it doesn't get dry. The sensors on these can be replaced for about half the price of the whole unit however. I don't know about the Lamotte ones, but if I saw a picture, I might be able to tell you who makes it.
    Essential Links:
    30,421
    Let's go back to the first post.....if you can tell below 7.5 and above 7.7, then simply keep it in that 7.5 - 7.7range and your pH will always be perfect
    Jan 2013
    Friendswood, TX
    320
    Yes, by process of elimination I could do that. However since I have had scale issues and I am concerned about the CSI over winter, I want the piece of mind that knowing the ph gives me.
    ~Paul
    38,301
    So then shoot for slightly less than 7.5.
    You can also get the acid / base demand reagents that let you change the color. I found this helpful to know what colors to look for.
    EDIT: Really you will likely never need the base demand. I use the acid demand almost every time I test to see how many drops it takes to get to 7.5 or 7.2
    Jan 2013
    Friendswood, TX
    320
    That was my original question. Using the acid demand, let's say my pool is 19k gal. and it takes 2 drops to get to 7.2. Other than checking with PoolMath is there a way to back calculate the starting ph?
    ~Paul
    38,301
    There should be a table in the test kit manual (AT least I think it is in the K-1000 that comes with the TF-100). Or you can find it online I am sure.
    Jan 2013
    Friendswood, TX
    320
    I have the table that is drops vs pool size and gives you MA required. What I was wanting to know is if there is a formula like:
    ph(starting)=equation based on "number of drops", "after drops ph", & "pool size"
    ~Paul
    38,301
    You can sort of figure that out using the table and PoolMath. Although I am not sure why it matters.
    Just count drops to get to desired pH and use the table to tell you how much acid to add. I wrote down the amount of acid per drop for me ... it is around 1/4 gallon.
    Jan 2013
    Friendswood, TX
    320
    That's what I am doing. Guess it's the best way. Just thought that if there was a formula I could keep it on my phone and it would be a little quicker.
    ~Paul
