Results 1 to 11 of 11
Thread: Stalled CC with SLAM, can I do anything more?
    Jul 2010
    Philadelphia
    134
    I have been slamming for about 9 days now. The pool on opening was a murky, brown mess.
    The CC has gone from 2 to 1.5 and hasn't budged in a while. I am keeping it at shock levels. Using the TF test kit
    I have a DE filter that doesn't need to be backwashed, pressure above starting pressure is maybe 4.
    I am brushing the pool daily and no longer see any dust or debris. I vacuum daily and am not getting much in the bag even after a 7 hour run. The water is totally clear now.
    There are flowers falling in the pool that I am trying to keep up with. Could that be the reason for the persistent CC?
    Should I backwash anyway to clear whatever detritus is in the filter? Opening pressure was 19, its now 23.
    Not sure why my CC has stalled.
    Thanks!
    19000 gal in ground, pebble tec. Sta-rite system 3 DE filter, Aquarite SWG, raypak 406A heater
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Re: Stalled CC with SLAM, can I do anything more?
    Hi Shacke,
    is your water clear?
    If it is, you might have some gunk behind the light fixture or in an autofil can or any water feature pipes that have been unused.
    the behind the light has stumped many a SLAM and caused the CC to stay high.
    TFP recommendation is to clean the filter when it rises 20 - 25% above the clean pressure.
    Divin Dave,
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I don't know if this helps your situation, but when we had flowers falling in our pool my cc also went up.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The simple answer also is time. It just takes a while sometimes to "burn" up everything. It will turn, just stick with it.
    Essential Links:
    Jul 2010
    Philadelphia
    134
    Quote Originally Posted by Defgufman View Post
    Thanks. That's helpful. Too make matters worse, I have a leak In a skimmer line which should be fixed today I hope. It's making it hard to clear the little flowers.
    the other possibilities Dave mentioned won't be the culprit with my pool.
    The pool is crystal clear. I wouldn't ever guess there was a chlorine demand
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    But there is. When it's all gone the CC will drop.
    Essential Links:
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I know it can be frustrating, but if you keep it up it is worth it in the end. I am glad you discovered your leak. I am sure that will help. When my CC finally started dropping it stalled at 1 for a long time. Keep it up!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jul 2010
    Philadelphia
    134
    What do you know. Patience was the key. CC now 0.5 and all is well. Thanks for forcing me to chill out!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by shacke View Post
    Yes POP (pool owner patience) is the key. Glad it finally dropped. How is your water looking?
    Lisa
    Jul 2010
    Philadelphia
    134
    Beeyoootiful! Chlorine dropping in the good weather so I hope to get in this weekend!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    That is great! Be very proud of yourself and enjoy your
    Lisa
