Thread: ultra frame 3" off level HELP!
    May 2015
    Edna
    1
    So we put our pool up today (it's an 18x48) and now it's off level. We leveled the ground first and then put a small layer of sand down. Most of the pool is within .5" but one leg sunk into the ground and it's off 3" in that spot. I really hate the Idea of wasting all of that water by draining it... are there any other options for me? Thanks for your help!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: ultra frame 3" off level HELP!
    Can you lift it and put a paver under it?
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by pooldv View Post
    this is what I'd try to do. You May have to dump some water to lift or jack the side up.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I would lift it and put a paver under it like the others said. It is best with 2 people lifting and someone to slide the paver under
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    jmcdtucson's Avatar
    Jun 2014
    317
    That sounds like a good plan. Remember safety first, that's a lot of weight. And get a BIG paver as long as you're doing it. I used 16"x16"x4"
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Mar 2014
    Gulf Breeze, Florida
    67
    I used a floor jack on my 24' Intex.... Used a length of 2x4 jammed under the top rail to lift it up enough to put a paver underneath.
    I was sweating it a bit but all worked out fine... It made some strange noises as I raised it.
    Chris Hawkins
    18,000 gallon vinyl Inground. Hayward Goldline Aquarite 40k SWG, Pentair Intelliflo VS pump.
    Polaris 3900 cleaner, Pentair Tagelus sand filter. AquaPro 1300 heat pump. TF-100
