Results 1 to 16 of 16
Thread: Can't keep algae gone for more than a day
    Aug 2013
    Stockton, Ca.
    23
    Thumbs up Can't keep algae gone for more than a day
    FC 6
    TC 6
    Calcium Hardness 100
    CYA 99
    TA 80
    PH 7.4
    Copper 0
    Iron 0
    Phosphates 200
    I put Phosfree into pull three times now (i started with reading of about 800 phosphates). I have cleaned filter before and after and now am putting maintenance **** in it every week. Doesn't seem to help. I can't get rid of it. I'm ready to move and forget this freaking pool . Help!!
    The pool math says remove 20% of pool water (earlier this year I removed 70 %). Also calcultor says add 355 oz of calcium chloride (really?). Will this make a difference in my algae??
    Thanks
    Chris M. 20k, inground, defilter, pebbletek, 1hp motor,Tiger Shark QC, TF-100, switched to liquid chlorine 3 years ago LOOOOVVVVEEEE it!
    Re: Can't keep algae gone for more than a day
    The key step is to get your CYA level down to something more reasonable. Most CYA tests will report any level above 100 as something around 100, so there is no telling just how high your CYA level really is.
    I would skip the phosphate remover. It is expensive and not needed.
    You do want to raise the calcium level. Otherwise you will be leaching calcium out of the plaster that is between the pebbles. But that is lower priority than the other issues.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    How have you been chlorinating your pool?
    Your signature says you have a TF100, but your numbers and the fact that you purchased Phosfree indicate you are still going to the pool store for testing?
    Support the site
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    If your tests and I mean the majority of tests are coming from the Taylor kits, your FC Is too low based off of your cya.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Aug 2013
    Stockton, Ca.
    23
    Yes I panicked!! Went to the store!! You caught me. I also ran out of my cya testing fluid!!
    Whats the FC suppose to be at?
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by chrismassod View Post
    I thought so....
    At CYA 100 FC should NEVER be below 7, target 12 or a little above.
    But, its too late for that now. You have to SLAM your pool, which is almost impossible at the levels of FC you would need. Plus, we are dealing with 100+ CYA, so as Jason said you need to drain water to get that CYA down.
    Oh, don't forget to reorder your test kit supplies.
    Support the site
    Aug 2013
    Stockton, Ca.
    23
    Thank you. It's pretty close to 100 (cya) . so you think about 20-25 % of water?
    May 2014
    Franklin, NC
    9,184
    Probably close to 40% to get back to recommended levels.
    I'm guessing 3" tabs and shock got you there?
    Support the site
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Looks like you need a good round of reading in some of the Pool School articles. Starting with ABCs of Pool Water Chemistry
    It's not practical to maintain proper FC or eliminate algae with CYA levels at 100 (or more, which I suspect it may be if you have not done a diluted water CYA test with a Taylor CYA test). IF your pool had no algae and the CYA were indeed 100, you would need to maintain a minimum of 7 FC at all times. NEVER below that. See Chlorine/CYA Chart. To eliminate an algae problem you would have to Shock Level and Maintain at 39 FC. You're much better off trying to eliminate algae starting with a much lower CYA level. See Defeating Algae and SLAM Procedure.
    It's a lot to take in, but if your going to commit to proven TFP methods, you have to have a recommended test kit and a willingness to learn and stick to the methods detailed here, not pool store advice. Mixing pool store advice/testing with TFP methods is just another recipe for disaster.
    Isolated Spa - 345 Gallons
    May 2014
    Franklin, NC
    9,184
    Or, you can go back to the pool store (image compliments of aussieta)
    Support the site
    Aug 2013
    Stockton, Ca.
    23
    Yeah Yeah yeah I'm getn the pic
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    i can't remember who originally made the wheel of fortune
    but i copied it from this site
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by aussieta View Post
    Well, I borrowed it from one of your posts.....
    I know Richard uses it a lot. It may be his.
    Support the site
    30,414
    I believed Richard 320 is responsible for that graphic. He has posted many great ones on the forum......Barney Fife may have been my favorite.
    May 2014
    Franklin, NC
    9,184
    I like his tanker truck.
    Support the site
    Jun 2011
    Austin, Texas
    206
    I'm lucky I found this site within a month or so of starting my pool. I had been under the care of a pool store, using choline tabs and shock, and to my good fortune I found this site before my CYA became too high.
    I now rely on TFP exclusively for my maintenance tips, and get my chemicals at either the grocery store, Walmart, or Home Depot.
    18 foot diameter, 52" tall above ground Cornelius pool, with vinyl liner, and resin wall caps.
    Roughly 7600 gallons
    Blue Wave "Sandman" Sand filter/pump, model NE6150. Pump is 1 HP
    Intex SWG, model # 54601E
