Results 1 to 9 of 9
Thread: Intex Leak
    May 2014
    Corona, CA
    21
    Intex Leak
    Hey all,
    I could really use some advice. So this year I decided to hard plumb my system and also add and extra inlet and outlet to my pool. Well now I have a leak where the strainers screw into my pvc pipe. I have already drained enough water to tighten the connections already and now do not want to have to drain again. If draining is my only option again I may have to give in and just not have my pool up this year. Attached is a photo.
    Intex 14'x42"
    Intex 14" 2800gal sand filter pump
    38,475
    Re: Intex Leak
    How fast is it dripping out? I would let it drip before giving up on the season.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Intex Leak
    Maybe get gasket material from Home Depot that you can cut and make a gasket to put between the connection.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2014
    Corona, CA
    21
    Re: Intex Leak
    I thought about a gasket but that would require draining the pool to a level to remove the strainer.
    The it drips about a drip every few second. My only worry about leaving it is what will happen when the pump is on. Will that drip turn into a stream?
    Is there a silicone glue or something similiar that I can use to put around the tread.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Intex Leak
    Only one way to find out what will happen when you turn the pump on. You probably lose more water to evaporation. You could put a bucket under it to see how much water it over a week. And you could pour it back in the pool for that matter.
    38,475
    Re: Intex Leak
    I have a few drips on my equipment pad too. Drive me nuts, but in the scheme of things, the water loss is negligible.
    Re: Intex Leak
    Mine did this to me, I read somewhere here where one suggested silicone caulking.
    I didn't think it would work being on the pressure side.
    But It worked for me!!! Never would have thought it would!
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
    May 2015
    Thailand
    5
    Re: Intex Leak
    if not straight silicone, wet silicone wrapped with cloth/fabric (for strength) before curing and squeezed into every mm during curing...
    OR
    Sugru! (it has served my poor pool very well)
    Intex 10' x 30" Easy Set (1,018Gal / 3,850 Ltr)
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Intex Leak
    If you had to seal it again you might want to try Megaloc : http://www.homedepot.com/p/Hercules-...8062/100153125
    This stuff is great for threaded fittings.
    Solar Blanket, Well Water, Borax Added. 68
