Results 1 to 10 of 10
Thread: Need opinions on Pool Math results!!
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    I'm hoping someone can help me be sure I'm understanding Pool Math correctly based on my info below. I've entered all of my test results and adjusted my goals according to Suggested Levels chart.
    - I see that I need to Increase CYA & TA.
    - Added salt just after testing.
    - Are my goals too high/low?
    - Is the water safe to swim at the current FC level until I can get the CYA up?
    - Is it necessary to increase CH? (vinyl liner)
    - CSI??? Is this high due to having more FC than what's recommended for my current CYA level? Should I be concerned about the current level?
    - Am I not concerned with Borates since the TF100 does not include a test for it?
    ​Jennifer
    19k gal, 27' x 54" AG Aqua Leader Saltwater 8000 installed April 2014; Aqua Pro 19" Sand Filter System 1.5-hp Pump; Hayward Aqua Trol Salt Chlorine Generator System; Overlap Boulder Swirl Liner; Polaris 65 Turbo Turtle Automatic Cleaner; TF-100 Testing Kit
    Re: Need opinions on Pool Math results!!
    There is no reason to add calcium to a vinyl pool. Nor do you need to worry about CSI much, unless your CH gets way high on it's own.
    Otherwise your goal levels look fairly reasonable. I might go a little higher on salt, so it is still reasonable at the end of the season.
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Quote Originally Posted by JasonLion View Post
    Thank you! And thank you for PoolMath - that's good stuff!
    I just read the thread about Borates (should have done that first) so I understand now why that's not necessary.
    What about the FC? Is that a safe level for swimming with such low CYA?
    Oh and how much higher would you suggest for salt?
    ​Jennifer
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Yes, it's safe to swim up to the shock level which is FC 16 with 40 CYA
    Support the site
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Quote Originally Posted by tim5055 View Post
    Thank you!
    ​Jennifer
    Mar 2015
    Georgia
    157
    SWG pools need more CYA to cut down on the "ON" time therefore making your SWG last longer than if it was on 100% all the time.
    If your pH is holding steady at 60 then you shouldn't need to increase TA, but that is as low as you can go. If your pH is decreasing then you definately need to increase TA until it holds steady.
    Water is safe to swim in up to "shock" levels which is 16ppm at that CYA level. You are far from that at 4.5ppm FC.
    No need to worry about CH with a vinyl pool. You are lucky to have a CH that low.
    Your CSI is likey in the negatives because your CH is low. No need to worry about it.
    Borates are optional. No need to worry about them until you get used to running your pool.
    16k AG Vinyl Sand Filter
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    Quote Originally Posted by smackdab View Post
    Thank you so much! You guys are awesome!
    ​Jennifer
    Apr 2014
    Milton, Florida 32572
    23
    Question about the calculator there where it ask for the temperature is that the water temp or the air temp outside?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by redline95240sx View Post
    Water temperature. It affects the Calcium Saturation Index - ie growing scale on the walls.
    And welcome!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    i case you havent found them yet..... handy references
    http://www.troublefreepool.com/conte...mmended-levels
    http://www.troublefreepool.com/conte...art-slam-shock
    Quote Originally Posted by *JLS* View Post
    Divin Dave,
