Results 1 to 14 of 14
Thread: What happens to muriatic acid in the pool?
    danimal67's Avatar
    Mar 2015
    San Diego, CA
    44
    I'm just curious as to what happens to the muriatic acid i pour into the pool?
    I understand it is lowering my PH and TA, then I can aerate to raise my PH back up and repeat to get my high TA under control.
    But does the acid break down as it lowers the PH? Is it consumed like the way chlorine is consumed as it does its job?
    I mean, once the acid does it's job, what is left behind? Water? Weak acid? An acid by-product?
    Just curious if anybody knows about this.
    Dan
    3300 Gallon Vinyl Intex AG Pool. 15'x 3' Round. 2100 GPH Intex Sand Filter/Pump.
    Installed summer of 2014. TF100 Testkit.
    Re: What happens to muriatic acid in the pool?
    Over simplifying a little, it turns into water and salt.
    Technically you get a hydrogen ion and a chloride ion.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Muriatic acid is really hydrochloric acid.
    May 2014
    Cincinnati, OH
    81
    H = hydrogen
    Cl = chlorine
    Na = sodium
    O = oxygen
    HCl (hydrochloric acid) + NaOH (sodium hydroxide) = NaCl (salt) + H2O (water)
    20x40' inground concrete pool
    approx 30,000 gallons
    1.5 hp hayward pump
    refinished spring 2015
    50 year old, newly remodeled in-ground 20x40' pool (approx 30,000 gallons)
    1.5 hp Hayward pump and 20 gpm/ft2 sand filter (62 gpm filtration&backwash), 50psi max working pressure
    danimal67's Avatar
    Mar 2015
    San Diego, CA
    44
    OK, interesting responses.
    So... any idea how much salt one gallon of muriatic acid leaves behind?
    I'm curious as to how much acid I could put in my small pool before it becomes a "saltwater" pool and starts to rust my metal.
    I imagine the amount of salt is quite low... just wondering if there's research on that.
    Thanks!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    In pool math towards the bottom there is a place you can enter the info to see the effects.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mar 2007
    San Rafael, CA USA
    12,082
    PoolMath will not tell you the amount of salt added from Muriatic Acid. One gallon of full-strength Muriatic Acid (31.45% hydrochloric acid) in 10,000 gallons will increase chloride ions by 35.5 ppm and is the increase in TDS. This calculation could be added to PoolMath.
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Could one put 32-36% HCl in there pool instead of MA?
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    MA is HCL.... Same stuff. Where are you talking about getting 32-36% ?
    Essential Links:
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Quote Originally Posted by Patrick_B View Post
    I make it at work, roughly 80GPM and currently have about 170K gallons on hand
    Wayne
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok, you'll have to adjust the dose down based on what you figure from Pool Math using 31.45%
    You'll have to experiment,!and be careful. Go a good bit smaller than what you think you will need. Obviously the adjustment will be less with 32% than 36. Good luck.
    Essential Links:
    danimal67's Avatar
    Mar 2015
    San Diego, CA
    44
    Man, you guys really are in the deep end!
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by Z7What View Post
    Wayne
    What kind of plant do you work at again? I swear I asked before, but I couldn't remember or find the post. They make some muriatic acid in the incinerator scrubber on the other side of my section of the plant. On my side's incinerator we just neutralize it with caustic.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Quote Originally Posted by n240sxguy View Post
    Chemical
    We make specialty chemicals and resins. The unit I run mixes two different chemicals in a reactor and one of the by products of it is HCL, we keep it between 35.2-36.7%
    Wayne
