Thread: pump replacement
    May 2015
    poway/ca
    3
    pump replacement
    i need to replace my 25 year old original doughboy single speed pump - i'd like to go with a variable speed PMM pump - the pentair superflo vs 342001 is appealing (i'm currently wired for 120v plus it has a nice user interface) but the energy star database shows that this new improved model is 1/3 as efficient as its predecessor (the 342000) - i spoke to someone at pentair but he was unable to explain the difference in performance and in fact did not seem to know what A-curve data was :0( does anyone have any experience with this pump?
    14,000 gal 16'x32' doughboy above ground pool with 3' inground deep end - hayward perflex extended cycle d.e. filter (25 sq.ft.)
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: pump replacement
    I think it is the error in the measurement at low speed so I wouldn't be too concerned about that. They both should be about the same efficiency.
    Mark
    May 2015
    poway/ca
    3
    Quote Originally Posted by mas985 View Post
    Mark - thank you so much for taking the time to respond to my question - it's people like you that enable DIY people like me to learn and get things done :0)
