Results 1 to 9 of 9
Thread: Is it normal to have CYA level drop?
    Jan 2015
    San Jose, CA
    237
    So I thought the only way to reduce CYA level was replacing water...
    My level has been about 35-40 since forever, but yesterday, when I tested my water it was only 20. So I decided to drop a few puck of tabs in my floaters and slammed the pool.
    SF Bay
    ********20,000 gallon IG Fiberglass, DE Filter, Hayward Max-Flo VS, Taylor TF-100 Test, Circupool RJ-45********
    38,284
    Re: Is it normal to have CYA level drop?
    CYA is consumed at a very low rate. Plus losses to splashout and backwashing and rain overflow.
    And sometimes over the winter it get converted to ammonia and drops to zero, although usually in a neglected pool.
    Jan 2015
    San Jose, CA
    237
    that's strange, I slammed my pool a few weeks ago, left it unattended for a week then had algae so I'm slamming again. For the most part, 0I only let my FC dropped to .5 for a few days, beside the green algae on the wall, the water is clear. Could there be something else wrong with the pool?
    SF Bay
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    The low FC allowed the algae to take off again. You need to repeat the SLAM process.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    38,284
    Yeah, if you ever let the FC drop below the minimum for your CYA, you could be heading for trouble.
    Jan 2015
    San Jose, CA
    237
    Been slamming for 2 days first day i spiked my fc 15 today its at 12.5 im going to let it drop down to 10 and see what happens if needed ill keep it there for a couple days but so far i see no algae.
    SF Bay
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    It is hard to see a low level algae outbreak. It is usually detectable by slimy side walls, filter clogging up faster, higher daily chlorine consumption. Then water gets progressively more cloudy. Then green.
    Jan 2015
    San Jose, CA
    237
    Thanks, ill keep an eye out. Can i test cya while slamming?
    SF Bay
    DFW, TX
    24,485
    Yes. PH is the only test that doesn't work with high FC.
