Thread: Another new home, 2nd pool. Observation.
    Aug 2008
    Pensacola, Fl
    57
    Purchased a new home in Pensacola in August 2014, with inground vinyl pool, shape of a stop sign. This is our 2nd pool, first was rectangle fiberglass inground. new pool has SWG and sand filter, unlike other one that had cartridge and liquid chlorine. Previous owner left us zero operating manuals.
    Anyway, filter pressure indicator had water inside, so I replaced it. Got same pressure readings of about 10psi. Sight glass on filter had a tiny bit of sand, but no water in it. Water in the pool nice and clear since day one, so I only added salt when required.
    Finally decided to backwash just for the heck of it. After all, the pressure gauge still at 10 psi. OMG was the water dirty. Looked like the muddy Mississippi River coming out the hose for a few seconds.
    Guess I need to backwash more often. Should the sight gauge always have water in it?
    About 23,200 gal vinyl in ground, "stop sign" shaped 22x22, Polaris 3900 cleaner, Hayward Aqua Plus Pro Logic Controller, Hayward T-15 SWG cell, Hayward S244T sand filter.
    38,275
    Re: Another new home, 2nd pool. Observation.
    The site glass will only have water in it when you backwash.
    Given the pool is new to you, I would suggest starting with Deep Cleaning your Sand Filter.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    The picture is still upside down.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Aug 2008
    Pensacola, Fl
    57
    Yeah, I noticed that too. Haven't figured out how to correct it yet.
    Thanks for the heads up!!
