Results 1 to 7 of 7
Thread: How to reduce noise from deck jets?
    Sep 2013
    Nashville, TN
    379
    We have 2 deck jets individually plumbed, when they are on it seems too loud so I have been trying to find a water to lower this without losing the distance of the arch. I contacted Jandy but they don't have other nozzle options. I found I could insert a piece of rubber tubing with a smaller hole and this achieves the desired result when my pump is on low speed but if high speed kicks in it will blow the tubing out of the nozzle. Any ideas as I would like to keep the deck jets on no matter the pump speed. I typically run on low with the valve for the deck jets and 3 returns on so I would think the returns would be able to handle the additional pressure provided on high speed which only runs 10 psi on filter gauge.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: How to reduce noise from deck jets?
    Is it the jet that is loud or the arcing watering hitting the pool water?
    Laminar jets might help if they are not already that type.
    Mark
    Sep 2013
    Nashville, TN
    379
    The water hitting the pool surface that is loud, our area is pretty quiet so it is probably more noticeable than if you were trying to drown out background noise
    mas985's Avatar
    Pleasanton, CA
    11,737
    You are fighting physics. The water needs to get to a certain height so that it can get the distance you want. The height ensures it hits the water with a certain velocity which it turn makes the noise.
    However, as I said before, a laminar jet may help some since the water is in a smooth stream when it hits the water but it will still make some noise.
    Mark
    Jul 2012
    Ohio
    10
    Related - I've got 8 deck jets -on two zones - each jet with their own ball valve so I can calibrate the arches with one another. I installed everything myself so of course it's totally over-engineered. Well - the first season they were great. Water came out in a very clean tight arch. Very little spray for the most part and overall not too loud.
    At the end of the first season I had the installer close the pool so I could see what they did and replicate the process going forward. When closing the jets - they literally took needle nose pliers and yanked the nozzles off the ball sockets by grabbing them through the outlet hole - totally screwing up the honed water outlet. The next season (last year) - the spray pattern was a disaster. The water arch was no longer tight and the noise from all the splashing water landing was MUCH louder. Very annoying.
    I'm getting ready to re-install this year - and before I do so, I'm going to spend some time trying to clean up the tips.
    20k In-ground Pool - 2 skimmers, dual main drains, 4 return jets, 4 hydro bench jets
    Pentair SD80 Sand Filter and Pentair RP 200 sq. ft. Cartridge Filter (swappable)
    Pentair 250k MasterTemp Heater
    IntelliChlor IC40
    Polaris 280 and Booster pump
    mas985's Avatar
    Pleasanton, CA
    11,737
    That is a really good example of what not to do. I would make them pay for new inserts.
    Mark
    Sep 2013
    Nashville, TN
    379
    I was able to use a 2 part epoxy and glue in a smaller piece of drip irrigation tubing, it now shoots out a smaller volume of water but still a good distance.
