Results 1 to 8 of 8
Thread: outdoor faucet
    outdoor faucet
    what brand did u guys use for sink faucet ? just looking for some ideas
    Propbndr's Avatar
    Mar 2015
    Charles City, Va
    232
    Re: outdoor faucet
    How fancy do you want it and how much money do you want to spend? Delta & Moen are both good brands and repair parts are readily available. You can find both at Lowes and Home Depot.
    Steve
    32 X 16 inground, 17260 gallons, Vinyl Liner, Triton II TR-60 filter,
    Sta-Rite 1hp pump Model #MPRA6E-147L, CircuPool SI-30 Plus SWG, TF-100 Test Kit
    4knights's Avatar
    NE Kansas
    419
    Re: outdoor faucet
    Quote Originally Posted by Propbndr View Post
    ^^^ what they said!
    Many choices when building the outdoor kitchen- You could spend $500 or more for a DCS, Viking, Lion, Lynx or Bull outdoor kitchen sink and faucet or get a single stainless bar base sink and faucet at the locall big box store.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Re: outdoor faucet
    not gonna go crazy it just turns on water and turns off water but want something thats gonna last. $300 is probably the budget
    4knights's Avatar
    NE Kansas
    419
    Re: outdoor faucet
    http://t.homedepot.com/p/Elkay-All-i...B&gclsrc=aw.ds
    There you go
    Depending on your location you may need to ensure there is a way to winterize it
    Riles_J's Avatar
    Nashville, TN
    218
    Re: outdoor faucet
    There are many single handle bar faucets for pretty cheap (under $100). That is what is on my ODK. I do have to winterize and drain though. I waited too long one year and busted up the faucet.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: outdoor faucet
    I like the idea of a basic stainless bar sink with a commonly-available faucet (e.g., Delta, Moen, Pfister). This combination will turn on/off the water just as good as the more expensive proprietary brands from the high-end grill makers. Availability of replacement parts is an important consideration.
    Jun 2011
    Carlsbad, NM
    172
    Re: outdoor faucet
    I went the other way. I bought the cheapest amazon faucet that fit the style I was after. With the elements, I figured it wouldn't last too long. I only have $70 in mine.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
